Results 1 to 9 of 9
Thread: Mini Vernier Height Gauge / Scriber / DIY Height gauge
    Supporting Member universal scale models's Avatar
    Aug 2020
    INDIA
    universal scale models's Tools
    Dear friends and followers, welcome back to my channel. This is a video about how to make a simple height gauge / scriber using a stage.A height gauge is a measuring device used for determining the height of objects, and for marking of items to be worked on.These measuring tools are used in metalworking or metrology to either set or measure vertical distances, the pointer is sharpened to allow it to act as a scriber and assist in marking out work pieces.Height gauges may also be used to measure the height of an object by using the underside of the scriber as the datum. The datum may be permanently fixed or the height gauge may have provision to adjust the scale, this is done by sliding the scale vertically along the body of the height gauge by turning a fine feed screw at the top of the gauge; then with the scriber set to the same level as the base, the scale can be matched to it. This adjustment allows different scribers or probes to be used, as well as adjusting for any errors in a damaged or re sharpened probe.In the tool room, the distinction between a height gauge and a surface gauge is that a height gauge has a measuring head (whether Vernier, fine rack and pinion with dial, or linear encoder with digital display), whereas a surface gauge has only a scriber point. Both are typically used on a surface plate and have a heavy base with an accurately flat, smooth underside.I hope you enjoyed this video and where able to learn something from it as well. Thanks for watching, have a great time making and enjoying these projects as I do Universal Scale Models
  2. The Following 6 Users Say Thank You to universal scale models For This Useful Post:
    BrianW (Sep 7, 2020), Canyonman44 (Sep 7, 2020), DIYSwede (Sep 6, 2020), Home-PC (Sep 9, 2020), Jon (Sep 7, 2020), SculptyWorks (Sep 7, 2020)
    Supporting Member Canyonman44's Avatar
    Mar 2014
    Hi, Do you have a website? Or how do I get to your "channel"?
    Ken
    Supporting Member Drew1966's Avatar
    Oct 2016
    Rare for me to turn up the sound on a video, but that Jazz was just too good to miss. Nice tool build too!
  5. The Following User Says Thank You to Drew1966 For This Useful Post:
    universal scale models (Sep 8, 2020)
    Aug 2020
    INDIA
    Hello , you can visit my website www.universalscalemodels.com and
    My youtube channel https://www.youtube.com/channel/UCq8...confirmation=1
    Thank you for your support
    Have a great day
    Aug 2020
    INDIA
    Thank you so much
    Oct 2016
    Quote Originally Posted by universal scale models View Post
    Thank you so much
    And that Jazz was?
  9. #7
    Aug 2020
    INDIA
  10. #8
    Dec 2017
    baja's Tools
    Quote Originally Posted by Drew1966 View Post
    And that Jazz was?
    Silence Walk Full, Anders Baldwin
  11. #9
    Thanks universal scale models! We've added your Height Gauge to our Height and Depth Gauges category,
    as well as to your builder page: universal scale models's Homemade Tools. Your receipt:
