Results 1 to 9 of 9
Thread: Mini plate compactor for sandstone slabs
    olefella's Avatar
    olefella's Tools
    Sandstone slabs are heavy and difficult to tamp to an even surface. A commercial plate compactor/vibrator is too heavy, damages the pavers and can crack them. This is a mini-compacter, made out of scrap I had in the antique department, weighs 30kg with a 1/4HP motor. Works well, cost nothing.
  2. The Following 15 Users Say Thank You to olefella For This Useful Post:
    AKpapa (Apr 27, 2020), Altair (Apr 20, 2020), baja (Apr 22, 2020), bobs409 (Apr 22, 2020), Drew1966 (Apr 26, 2020), EnginePaul (Apr 23, 2020), high-side (Apr 22, 2020), Inner (Apr 22, 2020), Jon (Apr 21, 2020), mwmkravchenko (Apr 21, 2020), rlm98253 (Apr 21, 2020), Scotty12 (Apr 21, 2020), Scrounga (Apr 21, 2020), sossol (Sep 20, 2023), Tooler2 (Apr 22, 2020)
    Thanks olefella! We've added your Mini Plate Compactor to our Miscellaneous category,
    as well as to your builder page: olefella's Homemade Tools. Your receipt:
    Jul 2019
    Mate, it doesn’t get any better than that. Works well+cost nothing=
    The only problem now is keeping it because when your mates find out you have one......you know the rest.
  5. The Following User Says Thank You to Scrounga For This Useful Post:
    rdarrylb (Apr 22, 2020)
    olefella's Avatar
    olefella's Tools
    You're not wrong Scrounga - one mate's already searching around for a compactor to do his path and I'm trying to avoid him. Never works!
  7. The Following 2 Users Say Thank You to olefella For This Useful Post:
    bobs409 (Apr 22, 2020), rdarrylb (Apr 22, 2020)
    Nov 2019
    Great idea! I need one to compact some sand in my barn that the bloody groundhogs tunnel through, and I don't want to spend $500 for one that I wouldn't use much. Never thought about an eccentric weight as the vibratory source. I had thought of a crank to an isolated bottom plate. Your idea is much simpler. I will be saving this for a future build!!!
    Feb 2015
    You shouldn't have to tamp the slabs if you've properly compacted the base. It's the whole point of having laid base-to provide a solid, stable surface to lay your paving on.
  10. #7
    Supporting Member Drew1966's Avatar
    Oct 2016
    Very nice. Why use Western Red Cedar as it’s worth over $100/metre? Cheapo pine would do the same job.
  11. #8
    Marion, Iowa
    metric_taper's Tools
    Your build is very interesting. I'm wondering, if you had a bit more offset weight on your rotating shaft, if it would momentarily jump in the air, allowing the operator to move it easier sideways. I'm in need of this same sort of machine for a garage slab foundation prep. I'm working right now.
  12. #9
    olefella's Avatar
    olefella's Tools
    Quote Originally Posted by Pa1963 View Post
    The slabs vary in thickness from 28-35 mm, and, while the undersurface is saw cut some have flakes broken off so it’s not always even. The base is compacted FCR, and I have brushed off all largish chips so it’s pretty flat and stable. There’s a layer of sharp sand under the slabs allowing them to settle so their top surface is even. I started off tamping them with a rubber mallet but they need a bit more hence the vibrater. I’ve laid smooth concrete slabs before, but not sandstone, so maybe I’ve got something wrong, but this seems to be going ok now.
