Thread: Milling Machine Head Removal and Holding Tools
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    In this video Andrew Spencer is going to demonstrate how to remove a milling machine head using a modified bar and a table mount system to be able to work on the milling head in a safe clean environment that is also safe an ergonomically friendly in other words you're not going to fall off a ladder or pull it muscle when you slip because you're standing on firm ground and the unit is firmly attached to a secure table
  2. The Following User Says Thank You to shopandmath For This Useful Post:
    Jon (Mar 14, 2024)
    Thanks shopandmath! We've added your Mill Head Holding Tool to our Machining category,
    as well as to your builder page: shopandmath's Homemade Tools. Your receipt:
