Results 1 to 5 of 5
Thread: Mill Table Light LED
    Dec 2016
    Ralphxyz's Tools
    Angry Mill Table Light LED
    I made a bracket to mount to my spindle for a DRO.
    and then decided I should add a LED which I got off superbrightleds
    These leds do not require a heat sink, I ordered a 70mm I could have gone for a larger (80mm-90mm) that would have given me more leds in the ring. The bracket takes up 1/4" inch so I lose 1/4" from spindle travel but it is off the top and I doubt I will miss it.
    I had to make a travel stop, as if I pushed the spindle all the way up it would pop off the bracket.
    The travel stop is not perfect as if the travel rod is rotated the spindle could still push the bracket off, I will have to keep my eye on it.
    I do not know how often I might rotate the travel rod to set a Z spindle max travel, we will see.
    Here you see how well the table is lit!
    And this is without the LED, of course my camera flashed so it is lit but you should see the difference.
    Now you see the lit table.
    Boy this forum software sucks it would not allow me to upload 1/2 my pictures.
    Just allowed some, others it rejected, all .jpg about the same size.
    I will try to add them to a reply.
    I have them on my Google Drive so let me know if you want to see all of them.
    Ralph
  2. The Following 3 Users Say Thank You to Ralphxyz For This Useful Post:
    drivermark (Mar 30, 2017), Paul Jones (Mar 31, 2017), Seedtick (Mar 30, 2017)
    Thanks Ralphxyz! We've added your Mill Spindle Bracket to our Milling category,
    as well as to your builder page: Ralphxyz's Homemade Tools. Your receipt:
    New plans added on 12/18/2024: Click here for 2,637 plans for homemade tools.
    Thanks Ralphxyz! We've added your Mill Light to our Lighting category,
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Ralphxyz,
    Great advice about the LEDs that do not require heat sinks. The photo posting software has it's quirks and after a while you will know what works and what doesn't work, and how to get around flipping the photos 90 degrees.
    Regards, Paul
    Dec 2016
    Ralphxyz's Tools
    Well I was doing some quick knock out milling on some plastic and had not thought about turning on the light.
    When I did WOW, what a difference!!
    Oh for those of you wondering, NO there is no shadow!!
    Ralph
