Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Mill depth stop improvement
    Like many mill-drills, mine came with a depth stop that consists of a threaded rod (1/2-20) with a longitudinal flat on it. (See first picture below.) The actual "stop" consisted of two nuts; one acted as the stop and the other as a lock nut to hold the stop in place.
    Calling it a poor design would be a compliment. The nuts had too little inertia to spin freely so one had to tediously turn them by hand, then repeat the same operation with the so-called lock nut. Precise adjustment was nearly impossible and the lock nut seldom stayed tight so the setting would drift.
    I solved part of the problem by turning a heavy, elongated brass nut (see second picture) that had enough inertia to spin rapidly up and down the thread if given a healthy twist. Rather than fuss with a lock nut, I threaded the stop for five 8-32 setscrews. Tightening one of these against the flat holds the stop in place with no chance of drift. I used five screws because that makes for a convenient setting interval. (1/5) * (1/20) = 0.01" so each setscrew position represents a 0.01 inch change in depth relative to its neighbors.
    I only use this stop when I need very fine control over the depth setting. For less demanding work, a clip-on commercial stop of the type shown in the third picture is quicker to use. It consists of a spring-loaded "clothespin" with a split hole threaded to match the depth rod. Repositioning it is done very easily and it doesn't slip but it does lack the fine position control of my design.
  2. The Following 14 Users Say Thank You to mklotz For This Useful Post:
    baja (Jan 6, 2021), lazarus (Jun 13, 2016), marksbug (Sep 28, 2018), Moby Duck (Apr 26, 2017), NortonDommi (May 27, 2018), Okapi (Jan 12, 2019), Paul Jones (Jun 13, 2016), paxx (Apr 26, 2017), rlm98253 (Apr 26, 2017), Scotsman Hosie (Mar 22, 2019), threesixesinarow (Jan 12, 2019), tonyfoale (Sep 5, 2023), Tonyg (Mar 22, 2019), Toolmaker51 (Apr 28, 2017)
    Thanks mklotz! We've added your Depth Stop Modification to our Milling category,
    Paul Jones (Jan 21, 2018)
    paxx's Avatar
    Hey Marv......thanks for posting this. I am wondering if you know where a guy could find one of those "clothes-pin" nuts?
    Paxx
    Quote Originally Posted by paxx View Post
    Hey Marv......thanks for posting this. I am wondering if you know where a guy could find one of those "clothes-pin" nuts? Paxx
    In a box of scrap aluminum, stir with a 1/2"-20 tap, hack saw, a small extension or torsion spring, 2 roll pins, and a pair of cap screws for handles.
  7. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Paul Alciatore (Oct 8, 2018), paxx (Apr 27, 2017)
    Below are a few places that sell them. If you want to search on your own, use the search term "Bridgeport depth stop" as these were originally supplied for that milling machine and so that name has become attached to them.
    https://www.amazon.com/Aluminum-Quic...ort+quill+stop
    https://www.amazon.com/HHIP-3900-020...ort+quill+stop
    https://www.mcmaster.com/#milling-ma...stops/=17dohe0
    Positioning Stops | Travers.com
    Accessories for Bridgeport milling machines - drawbars, work stops, replacement handles.
  9. The Following User Says Thank You to mklotz For This Useful Post:
    paxx (Apr 27, 2017)
  10. #6
    paxx's Avatar
    Toolmarker51..........thanks for the obvious suggestion that I didn't even consider........There is always great satisfaction in mixing tools, parts and a bit of time into a new tool or needed item!!! Thanks for pointing out the obvious....
    Marv........thankyou again!!! This had me stumped for a while as to what I needed to search for and I had just had figured that out before I got your reply. I appreciate the links and original post to give me something to look into to make my old Rockwell drill press a whole lot more useable.
    Paxx
  11. The Following User Says Thank You to paxx For This Useful Post:
    Toolmaker51 (Apr 27, 2017)
  12. #7
    It's not like we intend to undermine manufacturers; all of us weigh fabricating against purchase. Opening a wallet delivers zero sense of accomplishment. Knowing resources of collected HMT.net members varies infinitely, but innovation is not access to unlimited means to produce. It is utilization of that at hand spurred by creative thinking. A measure of confidence helps.
    Personally, I try to reinforce that what 'we' do is not just a hobby as some see it; replicating commercial results with unconventional methods. I don't see a demarcation twixt profit and avocation. If anything, investment in avocate pursuit is frequently more noble.
  13. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Paul Jones (Apr 30, 2017)
  14. #8
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hi Marv, , I tried to find one of those spring loaded ones but I see 40.00 to much how ever the set screws does appeal to ma by I'll try that Thanks for your input I like your as well. up date bought one on amazon THANKS MARV.....DROP BY ANYTIME..Cap
  15. #9
    Apr 2015
    Hi Marv
    Have ever seen a quick stop for a round column mill? I have a Grizzly G1007
    and the depth stop is very inconvenient.
    Jim D.
  16. #10
    Quote Originally Posted by Jim Deprey View Post
    Hi Marv
    Judging from the picture here...
    Mill/Drill w/ Variable-Speed Power Feed | Grizzly Industrial
    your mill has its depth indicator enclosed in the spindle housing. I can't even puzzle out how the "inconvenient" stop you mention works.
    Sorry, but I've never encountered a discussion of adding a depth stop to a machine like this.
