Results 1 to 4 of 4
Thread: Mill crank thumbwheel from scrap
    Supporting Member craig9's Avatar
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Lightbulb Mill crank thumbwheel from scrap
    Hi folks,
    My milling machine crank needed a new thumbwheel to make taking it on and off a lot easier.
    I just received the perfect offcut of steel to make it with, so watch the video to have a look at how I made it.
    I've added a bit of info about using digital calipers, and using an imperial lathe to work in metric, and using balanced cuts to hit a target dimension. Hopefully this is of use.
    Cheers,
    Craig
  2. The Following 4 Users Say Thank You to craig9 For This Useful Post:
    BrianW (Jun 12, 2020), Canyonman44 (Jun 26, 2020), Jon (Jun 18, 2020), mwmkravchenko (Jun 15, 2020)
    Thanks craig9! We've added your Mill Crank Thumb Wheel to our Machining category,
    as well as to your builder page: craig9's Homemade Tools. Your receipt:
    Supporting Member Skun Knuckles's Avatar
    Dec 2017
    Gippsland Victoria Australia
    Skun Knuckles's Tools
    A very informative and entertaining video. I have always disregarded digital verniers,and other electronic wizardry,now I'm having second thoughts.
  5. The Following User Says Thank You to Skun Knuckles For This Useful Post:
    craig9 (Jun 13, 2020)
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Thanks Skun. I resisted electronic measuring tools for way too long. I like reading a vernier, and I still marvel at how the offset markings can allow you to read such a small number so precisely - and there are downsides to digital tools like battery life, and so on - but once I switched to a digital caliper, I don't think I'll go back. I do still keep a good quality vernier in the drawer though, just in case I run out of batteries
    Cheers,
    Craig
