Page 27 of 60 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 ... LastLast
Results 261 to 270 of 596
Thread: Metric vs. other measurement systems - chart
  1. #261
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Also in the famous Christian proof that pi is equal to three...
    "And he [Hiram] made a molten sea, ten cubits from the one rim to the other it was round all about, and...a line of thirty cubits did compass it round about....And it was an hand breadth thick...." — First Kings, chapter 7, verses 23 and 26
    Yes, but, you see they had cubits for radii and longer cubits for circumference.
  2. #262
    Their god gave them a fairly exacting description of the box he wanted built...
    It is to be 2-1/2 cubits in length, 1-1/2 in breadth, and 1-1/2 in height.
    Given their freewheeling with the length of a cubit when building basins, they stood a good chance of botching the job and seeing a big finger pointing out of the sky and a booming voice, "You clumsy bastards, can't you get anything right?"
    What is the "molten sea" mentioned in the biblical quote? Was "sea" an ancient name for a basin or is this just another mistranslation like the "horns" on Moses' head?
  3. #263
    bruce.desertrat's Tools
    I think I've found the defiinitive set of measurments of the ship stuck in the Suez:
    "The vessel, operated by Taiwan-based Evergreen Group, is one of the biggest in the world: as long as four football fields, as wide as the wingspan of a Boeing 747, and, thanks to the 200,000 tons of containers stacked on board, as tall as a 12-story building."
    Why I'll bet the original blueprints used just those measurements :-) Lead Engineer "That diagonal there, it needs to be ⅓ football field by wingtip to the second engine."
    From https://arstechnica.com/gadgets/2021...he-suez-canal/
  4. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    jimfols (Mar 27, 2021), rgsparber (Mar 27, 2021), Toolmaker51 (Mar 27, 2021)
  5. #264
    Sep 2013
    Karl_H's Tools
    Quote Originally Posted by bruce.desertrat View Post
    Why I'll bet the original blueprints used just those measurements :-) Lead Engineer [I]"That diagonal there, it needs to be ⅓ football field by wingtip to the second engine.
    Problem is that the builder was just a Cessna hair off when measured!
  6. #265
    Apr 2016
    and the wheelhouse needs to be a baseball diamond. 2 ping pong table sized radars. partridge in a pare tree sized radio antenna.
  7. #266
    Dec 2015
    Reading, Berks, UK
    Your comments upset me a bit, but since you ask, I’ll tell you.
    The molten sea simply refers to the fact that it was cast from bronze. The Israelite women gave up their “brazen” mirrors. It was five cubits high and its capacity was 19,386 gallons. It was used for ritual cleansing. It was only filled two-thirds.
    The horn is a symbol of authority.
    The common Egyptian cubit, 6 palms of 4 digits each, is 6 to 7 of the Royal cubit, which Newton called “profane”. The sacred cubit, measured in the Jerusalem temple, measures 2.0736 feet and is in 6 to 5 ratio with the Royal, ie 30 digits. The Athenian foot is half a sacred cubit. (Source: John Neal)
  8. The Following User Says Thank You to Philip Davies For This Useful Post:
    hemmjo (Apr 10, 2021)
  9. #267
    Actually, they'd halve those measurements; aircraft drawings are almost exclusively left hand [port] side only. The right side is basically viewed 'through' the print to envision their form more clearly. Non symmetric items of course, have designated drawings.
  10. #268
    Proof positive superiorty of metrics compatability with imperial system
    Just my ~.02 worth.
  11. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    bruce.desertrat (Mar 30, 2021), marksbug (Mar 30, 2021)
  12. #269
    Lake Tahoe
    IntheGroove's Tools
    A huge asteroid three times the size of a London bus will zip between Earth and the moon tomorrow at a distance of just 159,000 miles, NASA has revealed...
  13. The Following User Says Thank You to IntheGroove For This Useful Post:
    FEM2008 (Apr 9, 2021)
  14. #270
    Jul 2019
    Ohio, USA
    Quote Originally Posted by IntheGroove View Post
    Or 2/3 the height of Arc De Triomphe, or ...
    Metric vs. other measurement systems - chart-41541650-9453483-image-30_1617971074913.jpg
  15. The Following User Says Thank You to FEM2008 For This Useful Post:
    Jon (Apr 9, 2021)
There are currently 6 users browsing this thread. (0 members and 6 guests)
