Results 1 to 10 of 14
Thread: Method for setting vee block centrally to machine spindle
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is the method I use for setting a vee block centrally to machine spindle.
    This is a quick method for setting up a vee block centrally to the machine spindle, be it a on a drill or mill.
    The first picture shows a piece of material which has been machined square in the lathe and is the setting piece.
    The second photo shows the setting bar being lowered in to the vee of the block using the machines quill. This centralises the vee block to the spindle.
    The third photo shows a parallel being clamped against the base of the vee block. This needs to be tighten and square to the block.
    The forth photo shows the vee block being moved along the parallel. This enables the work piece to be position without machining into the vee block but still maintaining the central position. (In this case I didn’t need to use the parallel as it is a piece of tube and I am only drill one side of the wall.
    The fifth photo shows the clamping of the vee block to the table, the left clamp is operated first with the vee block still against the clamped parallel to ensure the position is maintained.
    The sixth photo shows the parallel removed and the second clamp in position to ensure good clamping of the vee block.
    The seventh photo shows the centre drill ready to drill the component on its centre line.
    The setting bar is also used to clamp the vee block and horse shoe clamp together for storing.
    This isn’t a home-made tool but I hope you have found this useful for any future projects you where you might need to drill on the centre line of a shaft.
    The Home Engineer
    Download plans for milling tools.
  2. The Following 21 Users Say Thank You to thehomeengineer For This Useful Post:
    Andyt (Feb 26, 2020), astroscuba (Aug 19, 2023), Captainleeward (Jan 20, 2018), davesrepair (Aug 6, 2024), Eaglewood (Nov 17, 2022), emu roo (Nov 17, 2022), Harvey Melvin Richards (May 24, 2018), JD62 (Jan 20, 2018), Jon (Jan 20, 2018), metric_taper (Jan 20, 2018), Moby Duck (Jan 20, 2018), mr mikey (Jul 19, 2022), Philip Davies (Feb 26, 2020), PJs (Jan 28, 2018), RetiredFAE (Jul 18, 2022), Seedtick (Jan 20, 2018), that_other_guy (Aug 18, 2023), Tonyg (Feb 26, 2020), Toolmaker51 (Nov 18, 2022), trevor_60_r (Nov 18, 2022), Z2V (May 24, 2018)
    Thanks thehomeengineer! We've added your Vee Block Centering Method to our Measuring and Marking category,
    Dec 2016
    Ralphxyz's Tools
    Love those holddown clamps!!
    Can't wait to make some.
    Thanks for posting I need this.
    Ralph
  5. The Following User Says Thank You to Ralphxyz For This Useful Post:
    thehomeengineer (Jan 21, 2018)
    Apr 2019
    Hello and AWESOME work! Any chance you can add the specs of those clamps in the pictures? They look very useful and just what I’m looking for.
    Thanks again,
    MoBo
  7. The Following User Says Thank You to MVBowker73 For This Useful Post:
    thehomeengineer (Feb 26, 2020)
    Berkshire UK
    Hi
    thank you for your interest below is a link to the claw clamp drawings in the plans for sale forum.
    https://www.homemadetools.net/forum/claw-clamps-68771
    many thanks again
    The Home Engineer
  9. The Following User Says Thank You to thehomeengineer For This Useful Post:
    MVBowker73 (Feb 26, 2020)
  10. #6
    Dec 2016
    Ralphxyz's Tools
    Thanks bought it!!
    Ralph
  11. The Following User Says Thank You to Ralphxyz For This Useful Post:
  12. #7
    Berkshire UK
    Hi Ralph
    Thank you for purchasing the drawings I would appreciate any feedback good or bad on the content of the drawing pack. I would also like to see some photos once you have completed them.
    All the best
    The Home Engineer
  13. #8
    Dec 2016
    Ralphxyz's Tools
    Don't hold your breath waiting to see what I might do with the Claw Clamps. They are on a very long ToDo list.
    I really like having drawings as you just never know what opportunities might arise, at least having the drawings ...
    Ralph
  14. #9
    Berkshire UK
    I know exactly what you mean someone bought me a sign that said: “I have so many projects and I am so far behind, I haven’t got time to die.”
    But if you do get a chance to make I am sure you won’t be disappointed I use mine all the time. I have made at least 8 large ones and two half size. I have adapted some Bosch extrusion as packers so the height can be increased to hold larger/ higher components. I will post to show you in a new post.
  15. #10
    Berkshire UK
    Link to Bosch extrusion packers for claw clamps
    http://www.homemadetools.net/forum/c...p-system-65679
