Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Metal polishing advice
    May 2012
    Byron, Michigan
    astroracer's Tools
    These are the wheels on my truck. Most people would have never seen the defects in the wheels but I am pretty picky about how my truck looks and was not happy with them. now I am...
  2. The Following 4 Users Say Thank You to astroracer For This Useful Post:
    extropic (Oct 30, 2017), Paul Jones (Nov 6, 2017), rendoman (Oct 30, 2017), Seedtick (Nov 1, 2017)
  3. #12
    Nov 2015
    Italy
    rendoman's Tools
    Impressive work!!
    Usually I use aluminum and brass, I'll have to polish a couple of damascus blades. I bought 5000 grit as experiment to restore a stringht razor, since I havn't the complete set of stones in order to sharp the edge.
  4. The Following User Says Thank You to rendoman For This Useful Post:
    astroracer (Oct 30, 2017)
  5. #13
    Hammer1963's Avatar
    Sep 2015
    Bourbon capital USA
    Quote Originally Posted by astroracer View Post
    Thank you for sharing your technique. This is FANTASTIC work! I am relieved to see that I am not the only one with this sort of obsession when it comes to refinishing wheels. I perform wheel repairs and refinishing weekly and I strive to have the finished product better than pre-damage condition regardless of whether it is painted, machined or a polished surface.
  6. The Following User Says Thank You to Hammer1963 For This Useful Post:
  7. #14
    May 2012
    Byron, Michigan
    astroracer's Tools
    Thank you sir, much appreciated! Especially from a pro!
    Mark
  8. #15
    Hammer1963's Avatar
    Sep 2015
    Bourbon capital USA
    Fantastic!
    Your work far exceeds most of what I see on a regular basis. Have you applied a clear coat to the wheel to preserve your work?
  9. #16
    May 2012
    Byron, Michigan
    astroracer's Tools
    No clear coat. I avoid clear coats of any kind. I just keep them polished with White Diamond. If you haven't used it pick some up. It is amazing.
    Mark
  10. The Following User Says Thank You to astroracer For This Useful Post:
  11. #17
    Hammer1963's Avatar
    Sep 2015
    Bourbon capital USA
    Mark
    Thanks for the info. I generally use Gord's but I am always looking to try a new product
  12. #18
    Apr 2016
    been there done that...toomany times...and th quality/grade of the aluminum make a big differance too. problem I have is stopping corrosion and not having to polish every 2 weeks or less to keep spots away. cast are horrific,my douglass wheels Im pretty sure are hydrofroged. I have some spun wheels that are ...welll...skeery to look at. I took off those wheels, just toomuch up keep.
