Results 1 to 5 of 5
Thread: A Master Socket Table
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Here is a table of SAE and metric sizes that can be used to select a socket or wrench.
    If you are interested, please, click here.
    Thanks,
    Rick
    Rick
  2. The Following 7 Users Say Thank You to rgsparber For This Useful Post:
    baja (Nov 4, 2020), Canyonman44 (Nov 8, 2020), clydeman (Nov 2, 2020), EnginePaul (Nov 3, 2020), olderdan (Nov 3, 2020), rebuilder1954 (Nov 2, 2020), sak778 (Nov 2, 2020)
    Interleaving metric and inferial sizes is useful when drilling as well. The DRILL program on my page has an option to find the drill(s) closest to a user-specified size. This necessitated inputting the sizes of the metric drills as well as all the idiot notations and sizes for the inferial drills. Having that data to hand made it easy to write a short program to interleave all the data and produce the drill chart below.
    Code:
    Drill Sizes:
                    97  0.0059
                    96  0.0063
                    95  0.0067
                    94  0.0071
                    93  0.0075
                    92  0.0079
                    91  0.0083
                    90  0.0087
                    89  0.0091
                    88  0.0095
                    87  0.0100
                    86  0.0105
                    85  0.0110
                    84  0.0115
                    83  0.0120
                    82  0.0125
                    81  0.0130
                    80  0.0135
                    79  0.0145
        1/64..........  0.0156
                    78  0.0160
                    77  0.0180
                    76  0.0200
                    75  0.0210
                    74  0.0225
                    73  0.0240
                    72  0.0250 000-120
                    71  0.0260
                    70  0.0280
                    69  0.0292
                    68  0.0310
          1/32........  0.0313
                0.8 mm  0.0315
                    67  0.0320
                    66  0.0330
                    65  0.0350
                0.9 mm  0.0354
                    64  0.0360 00-90
                    63  0.0370
                    62  0.0380
                    61  0.0390
                1.0 mm  0.0394
                    60  0.0400
                    59  0.0410
                    58  0.0420
                    57  0.0430
                1.1 mm  0.0433
                    56  0.0465
        3/64..........  0.0469 0-80
                1.2 mm  0.0472
                1.3 mm  0.0512
                    55  0.0520
                    54  0.0550 1-56
                1.4 mm  0.0551
                1.5 mm  0.0591
                    53  0.0595 1-64,72
            1/16......  0.0625
                1.6 mm  0.0630
                    52  0.0635
                1.7 mm  0.0669
                    51  0.0670
                    50  0.0700 2-56,64
                1.8 mm  0.0709
                    49  0.0730
                1.9 mm  0.0748
                    48  0.0760
        5/64..........  0.0781
                    47  0.0785 3-48
                2.0 mm  0.0787
                    46  0.0810
                    45  0.0820 3-56,4-32
                2.1 mm  0.0827
                    44  0.0860 4-36
                2.2 mm  0.0866
                    43  0.0890 4-40
                2.3 mm  0.0906
                    42  0.0935 4-48
          3/32........  0.0938
                2.4 mm  0.0945
                    41  0.0960
                    40  0.0980
                2.5 mm  0.0984
                    39  0.0995
                    38  0.1015 5-40
                2.6 mm  0.1024
                    37  0.1040 5-44
                2.7 mm  0.1063
                    36  0.1065 6-32
        7/64..........  0.1094
                    35  0.1100
                2.8 mm  0.1102
                    34  0.1110 6-36
                    33  0.1130 6-40
                2.9 mm  0.1142
                    32  0.1160
                3.0 mm  0.1181
                    31  0.1200
                3.1 mm  0.1220
               1/8----  0.1250
                3.2 mm  0.1260
                    30  0.1285
                3.3 mm  0.1299
                3.4 mm  0.1339
                    29  0.1360 8-32,36
                3.5 mm  0.1378
                    28  0.1405 8-40
        9/64..........  0.1406
                3.6 mm  0.1417
                    27  0.1440
                3.7 mm  0.1457
                    26  0.1470
                    25  0.1495 10-24
                3.8 mm  0.1496
                    24  0.1520
                3.9 mm  0.1535
                    23  0.1540
          5/32........  0.1562
                    22  0.1570 10-30
                4.0 mm  0.1575
                    21  0.1590 10-32
                    20  0.1610
                4.1 mm  0.1614
                4.2 mm  0.1654
                    19  0.1660
                4.3 mm  0.1693
                    18  0.1695
       11/64..........  0.1719
                    17  0.1730
                4.4 mm  0.1732
                    16  0.1770 12-24
                4.5 mm  0.1772
                    15  0.1800
                4.6 mm  0.1811
                    14  0.1820 12-28
             13-4.7 mm  0.1850 12-32
            3/16......  0.1875
             12-4.8 mm  0.1890
                    11  0.1910
                4.9 mm  0.1929
                    10  0.1935
                     9  0.1960
                5.0 mm  0.1969
                     8  0.1990
                5.1 mm  0.2008
                     7  0.2010 1/4-20
       13/64..........  0.2031
                     6  0.2040
                5.2 mm  0.2047
                     5  0.2055
                5.3 mm  0.2087
                     4  0.2090
                5.4 mm  0.2126
                     3  0.2130 1/4-28
                5.5 mm  0.2165
          7/32........  0.2188
                5.6 mm  0.2205
                     2  0.2210
                5.7 mm  0.2244
                     1  0.2280
                5.8 mm  0.2283
                5.9 mm  0.2323
                     A  0.2340
       15/64..........  0.2344
                6.0 mm  0.2362
                     B  0.2380
                6.1 mm  0.2402
                     C  0.2420
                6.2 mm  0.2441
                     D  0.2460
                6.3 mm  0.2480
                 E-1/4  0.2500
                6.4 mm  0.2520
                6.5 mm  0.2559
                     F  0.2570 5/16-18
                6.6 mm  0.2598
                     G  0.2610
                6.7 mm  0.2638
       17/64..........  0.2656
                     H  0.2660
                6.8 mm  0.2677
                6.9 mm  0.2717
                     I  0.2720 5/16-24
                7.0 mm  0.2756
                     J  0.2770
                7.1 mm  0.2795
                     K  0.2810
          9/32........  0.2812
                7.2 mm  0.2835
                7.3 mm  0.2874
                     L  0.2900
                7.4 mm  0.2914
                     M  0.2950
                7.5 mm  0.2953
       19/64..........  0.2969
                7.6 mm  0.2992
                     N  0.3020
                7.7 mm  0.3031
            5/16......  0.3125 3/8-16
                8.0 mm  0.3150
                     O  0.3160
                     P  0.3230
       21/64..........  0.3281
                     Q  0.3320 3/8-24
                8.5 mm  0.3346
                     R  0.3390
         11/32........  0.3438
                     S  0.3480
                9.0 mm  0.3543
                     T  0.3580
       23/64..........  0.3594
                     U  0.3680 7/16-14
                9.5 mm  0.3740
               3/8----  0.3750
                     V  0.3770
                     W  0.3860
       25/64..........  0.3906 7/16-20
               10.0 mm  0.3937
                     X  0.3970
                     Y  0.4040
         13/32........  0.4062
                     Z  0.4130
       27/64..........  0.4219 1/2-13
            7/16......  0.4375
       29/64..........  0.4531 1/2-20
         15/32........  0.4688
       31/64..........  0.4844 9/16-12
                   1/2  0.5000
       33/64..........  0.5156 9/16-18
         17/32........  0.5313
       35/64..........  0.5469
            9/16......  0.5625
       37/64..........  0.5781
         19/32........  0.5938
       39/64..........  0.6094
               5/8----  0.6250
       41/64..........  0.6406
         21/32........  0.6562
       43/64..........  0.6719
           11/16......  0.6875
       45/64..........  0.7031
         23/32........  0.7188
       47/64..........  0.7344
                 3/4==  0.7500
       49/64..........  0.7656
         25/32........  0.7812
       51/64..........  0.7969
           13/16......  0.8125
       53/64..........  0.8281
         27/32........  0.8438
       55/64..........  0.8594
               7/8----  0.8750
       57/64..........  0.8906
         29/32........  0.9062
       59/64..........  0.9219
           15/16......  0.9375
       61/64..........  0.9531
         31/32........  0.9688
       63/64..........  0.9844
                  1 in  1.0000
      1-3/64..........  1.0469
      1-7/64..........  1.1094
             1-1/8----  1.1250
     1-11/64..........  1.1719
        1-7/32........  1.2188
               1-1/4==  1.2500
     1-19/64..........  1.2969
       1-11/32........  1.3438
             1-3/8----  1.3750
     1-27/64..........  1.4219
                 1-1/2  1.5000
  4. The Following 8 Users Say Thank You to mklotz For This Useful Post:
    baja (Nov 4, 2020), Canyonman44 (Nov 8, 2020), emu roo (Nov 3, 2020), Home-PC (Nov 3, 2020), jimfols (Nov 2, 2020), oldguy55 (Dec 23, 2020), rebuilder1954 (Nov 2, 2020), sak778 (Nov 2, 2020)
    Thanks rgsparber! We've added your Socket Table to our Fastening category,
    Teague (Nov 2, 2020)
    olderdan's Tools
    Thanks Rick, your socket reference table will be a useful resource to me but not for your intended propose. I have to make many special bolts and nuts for vintage bikes and your table will be a quick reference for close compromise sizes.
  8. The Following User Says Thank You to olderdan For This Useful Post:
    rgsparber (Nov 3, 2020)
    Supporting Member Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Inferial? :-) Sorry Marv.
