Results 1 to 6 of 6
Thread: Manufacturing motorcycle fuel tanks - GIF
    May 2024
    Manufacturing motorcycle fuel tanks.
    Aircraft fuel tank inspection - GIF
    Fuel tank drilling fire - GIF
    Fuel tank welding fire - GIF
    Airplane fuel tanks turned into Vietnamese boats
    rlm98253 (Sep 22, 2024)
    Supporting Member basil3w's Avatar
    Mar 2012
    When the upper and lower tank components are assembled, is it a friction welding process?
    Quote Originally Posted by basil3w View Post
    Friction welding can only be done with spinning parts in the opposite directions the process you see for seam welding is exactly the same as induction spot welding only the two contactors are rotated while the seam of the tank is pulled between them
  5. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    charles scozzari (Sep 21, 2024), Gadgeteer (Sep 21, 2024), rlm98253 (Sep 22, 2024)
    Mar 2012
    Thanks Frank!
  7. The Following User Says Thank You to basil3w For This Useful Post:
    Frank S (Sep 22, 2024)
    Apr 2012
    NorCal
    Saltfever's Tools
    Its "conduction" like a spot welder with metal-to-metal contact. "Induction" is heating through electrical resistance with non-contact.
  9. The Following User Says Thank You to Saltfever For This Useful Post:
    Frank S (Sep 24, 2024)
  10. #6
    Thank you we always called it induction but you are correct
