Results 1 to 4 of 4
Thread: Manual wire spool winder - GIF
  2. #2
    Mar 2018
    Looks more like solder? Especially since they just pull up on it to break it and go to the next spool. Also there's only about a yard (.9144 meters) of material being wound. Not much "wire"
    hemmjo's Tools
    And you can see the rag in the left hand is discolored from the metal sliding through it.
  4. #4
    Hoosiersmoker;
    hemmjo;
    As usual, that particular foreign writing is caption enough. It says "If a little is good, less is better, not enough is just right."
    We've not the facts or justifications about decent spools with so little material, but I have low tolerance for inadequate,
