Results 1 to 10 of 14
Thread: Manual Wire Feeder for TIG Welding Thin Metal
    Supporting Member chy_farm's Avatar
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Things I mostly enjoy TIG welding are small engine parts like power pipes, carburetor attachments and etc. made from mostly 0.5mm thick steel sheet. The parent material of this thickness needs small wire, 0.6mm in diameter as far as my welding skill concern but this wire mostly come to us wraped on a round plastic reel so that they get curly or curved when released from the reel. This causes me trouble in trying to give the part some precision work, so I had to hold the wire as close as possible to the aiming melting pool with the other hand.
    This manual wire feeder helps me a lot in this sort of precision works.
    The only one mechanism came from a used disposable cigarette lighter, using the round file that makes small sparks to light the gas. Remove the lighting stone out but use the spring inside. Add a small plate, cut in a right shape to fit in, so as the spring pushes this plate upward to press the wire on to the round file above.
    One tip for smoother movement is that you should better use a Teflon tube for the lead part between this reservoir box and the feeder. I tried another material but was not very good though.
    Chy
  2. The Following 17 Users Say Thank You to chy_farm For This Useful Post:
    Andyt (Aug 1, 2018), blkadder (Aug 1, 2018), buster69 (Jun 11, 2020), Corm (Apr 7, 2018), high-side (Jun 12, 2020), Jon (Apr 7, 2018), KustomsbyKent (Jun 11, 2020), mwmkravchenko (Apr 7, 2018), olderdan (Apr 7, 2018), PJs (Aug 1, 2018), rossbotics (Apr 8, 2018), Scotsman Hosie (Jul 31, 2018), Seedtick (Apr 7, 2018), sossol (Jul 31, 2018), thehomeengineer (Apr 9, 2018), Tuomas (Apr 7, 2018), yvonf (Jun 12, 2020)
    Jyväskylä Finland
    Tuomas's Tools
    That looks to be actually very handy. Using seems to be similar with feeding with bare hand. Good idea!
  4. The Following User Says Thank You to Tuomas For This Useful Post:
    chy_farm (Apr 7, 2018)
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Thanks Tuomas, yep that is what I payed some amount of attention to it, lol. Feeding wire bare handed most often requires me to move my fingers, in my case I use thumb and index, from the left to the right. This movement somewhat gives the end of the filler wire some swinging motion around the melting pool. I do this right with bigger rods like 1.2mm rods or more but as far this small curly wire concern I need more stability to the motion.
    In this aspect this tool helps me a lot since I can do fill the wire with my thumb pushing downward, which is less movement than the another way.
    Chy
    Thanks chy_farm! We've added your TIG Wire Feeder to our Welding category,
    as well as to your builder page: chy_farm's Homemade Tools. Your receipt:
  7. The Following User Says Thank You to DIYer For This Useful Post:
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Thank you for this add, glad you like this!
    Berkshire UK
    thehomeengineer's Tools
    Very useful when wearing gloves, it can be difficult to feed the rod. Another item added to the list to have a go at.
    Thank you for posting
    The Home Engineer
  10. The Following User Says Thank You to thehomeengineer For This Useful Post:
  11. #7
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Quote Originally Posted by thehomeengineer View Post
    The Home Engineer
    Good morning Thehomeengineer, glad you like this!
    Chy
  12. #8
    Quote Originally Posted by chy_farm View Post
    [ATTACH=CONFIG]23103[ATTACH]
    Chy
    Thank you for.......helping me get my head screwed on straight. As I .......enter the senior stage of life, I find that my manual dexterity suffers. I was thinking of making a small wire feeder for TIG wire, but as usual I over complicated it with using a feeder from an old Mig machine with another foot pedal to advance the wire etc. Your idea got me back on track as far as the KISS principal. Even I can still move my thumb, so I don't need the *feel* as much. This is the perfect solution.
    Denny
  13. #9
    Clever, free, and we don't see this very often.
  14. The Following User Says Thank You to Jon For This Useful Post:
  15. #10
    Exactly Jon. Probably because of the tremendous advances in technology, I tend to over engineer sometimes. This is the perfect example of not needing space shuttle technology to solve a toilet paper holder problem.
  16. The Following User Says Thank You to ibdennyak For This Useful Post:
