Results 1 to 5 of 5
Thread: Manual Numerical Control Ball Turning Program
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This user friendly program runs on a TI-83 Plus calculator. You input the finished ball diameter and the finished diameter of the shank attached to the ball. The program then guides the user in all machining operations.
    If you are curious about how CNC actually forms a surface or if you just want to cut balls on your lathe, this program may be of use to you. It can also be used to rough cut the ball before using a form tool or a ball turning attachment.
    For details, see
    http://rick.sparber.org/BTMNC.pdf
    For a copy of the program, contact me directly at rgsparber@aol.com
    Rick
  2. The Following User Says Thank You to rgsparber For This Useful Post:
    kbalch (Jul 15, 2013)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Rick! I've added your Ball Turning Program to our Lathes category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I just posted an upgraded version of the program. It now handles balls, crowned ends to round stock, and can put a "full radius" on a disk. Same URL.
    Rick
  5. The Following User Says Thank You to rgsparber For This Useful Post:
    kbalch (Jul 19, 2013)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks, Rick!
    Great stuff, as always.
    Ken
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Ken,
    You are welcome. I do hope I get a few beta testers so the program can be improved.
    Rick
