Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Making USB Cables Behave
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I have a few USB cables that are left connected when not in use. It is mildly annoying that they never want to stay coiled up. This article explains how I re-educated these cables so they naturally go into a coil when not in use.
    http://rick.sparber.org/MUCB.pdf
    Thanks,
    Rick
    Rick
  2. The Following 10 Users Say Thank You to rgsparber For This Useful Post:
    bobs409 (Jun 10, 2018), Captn Roy (Jun 12, 2018), Harvey Melvin Richards (Jun 10, 2018), oldcaptainrusty (Jun 10, 2018), olderdan (Jun 10, 2018), Paul Jones (Jun 13, 2018), Scotsman Hosie (Jul 30, 2020), Seedtick (Jun 10, 2018), VinnieL (Jul 28, 2020), volodar (Jun 11, 2018)
    olderdan's Tools
    Another clever trick for making life easier, I will try that tomorrow.
    Thanks for posting.
    Dec 2016
    bobs409's Tools
    I especially like the red dot idea! It's a 50/50 chance you'll get it right but rarely happens. lol
  5. The Following User Says Thank You to bobs409 For This Useful Post:
    PJs (Jun 11, 2018)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Yeah, when I'm so dopy that I still plug the USB in wrong, it is time for a nap...
    Rick
    Rick
    I just checked through the dozen plus USB rechargers in the basket by my desk and every one has the usb icon...
    http://www.usb.org/developers/docs/icon_design.pdf
    in bas-relief on the female side of the jack. Thus if you have the icon face-up when you insert it into a horizontally oriented receptacle, all will be well.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Marv
    You must live right. My PC and my wall warts have no markings.
    Rick
  9. #7
    Marv
    No, the marks are on the JACKS that are inserted into the receptacles in the PC, wall wart, etc. My wall warts have no markings, nor does the USB extension cord that brings access to the PC USB receptacles up to my desktop.
  10. #8
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Marv,
    The red dot is redundant on the jack but the one on the PC or wall wart is not. I can more easily see a red dot on the cable than the logo so add it.
    Rick
  11. #9
    my laptop has both the USB 2.0 and the USB 3.0 jacks they are opposite in orientation 3.0 icon up 2.0 icon down
    the usb jacks I hate are the mini jacks +-
  12. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Cool Idea Rick. I Like the red dot too and will use that trick especially on wall warts. I like the color coding instead of trying to read braille in low light with trifocals. I like to use Velcro cable ties for some of those longer ones and bundles too. Once coiled and tied they will retain the coil after a short time. But for Cphones or tablets that you may need to pull out further...yours is a Good Ideer.
    Also like the idea of retractable ones but found the commercial ones not overly reliable.
    It's funny about USB cables either being too long or two short and then of course "which version" of ends for which devices. The cable mfg's must be having conniptions and making a mint between USB, HDMI, & ethernet.
    I think this is current for USB...
    I'm also in the midst of routing all new Ethernet Cat 7 cables for to achieve max throughput and reliability as soon as they get here. May try your trick on them as well because the CAT7 have thicker shield and coating. I'll do a test to make sure they aren't damaged but should work I think.
    Thanks for the trick!
    PJ
    Mark Twain
