Results 1 to 8 of 8
Thread: Making a stand
    Jyväskylä Finland
    Tuomas's Tools
    Making a stand
    In this video.
    I will make a sturdy stand using steel.
    This one was made for a rr-track anvil, but it can be used for a bench vise, drill press or something like that too.
    Idea on the design is that height can be set suitable for the owner. Also its easy to take a part for the delivery.
    Space under the mounting plate can be filled with
    sand / steel.. To dampen the noise, or gain more weight to it.
    If this would have been for my use, i would have used rivets instead of bolt connections.
    Also, it has nice room for the legvise too, beside the anvil.
  2. The Following 6 Users Say Thank You to Tuomas For This Useful Post:
    cogentia (Feb 8, 2021), DIYer (Feb 8, 2021), IAMSatisfied (Feb 8, 2021), Jon (Feb 9, 2021), Toolmaker51 (Feb 15, 2021), Tule (Feb 9, 2021)
    Thanks Tuomas! We've added your Anvil Stand to our Dollies and Stands category,
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    Absolutely beautiful stand... thanks much for sharing!
  5. The Following User Says Thank You to IAMSatisfied For This Useful Post:
    Tuomas (Feb 9, 2021)
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by IAMSatisfied View Post
    Thank you very much for your nice comment.
    Frank S and I have batted about various fillers as you Tuomas; the conclusion is against mixed concrete though raw cement is ok. Concrete would shrink and loosen, but minimized by taper, smaller at the top. Sand lightly saturated with oil was arrived at, being most available and easily dispensed. Sand, oil and scrap would get higher weight yet per cube, without settling or voids.
  8. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Tuomas (Feb 17, 2021)
    Jyväskylä Finland
    Tuomas's Tools
    I planned that using rough sand could be good for this.
    I didn't make any bigger testing, but my thoughts we're that sand could possible reduce recoil. Like in deadplow hammer. So, it shouldn't be filled full.
    Someday i make another one to myself too. Then i can say is there difference.
  10. #7
    Dry beach type sand will dead blow even if full, not pounded in perhaps, just topped off then damp with oil. It settles and xx-viola-xx; voila!
    Thinking not possible to hit an anvil/ stand hard enough to encourage any degree of rebound. The loose dead weight isn't solid, so is difficult for it to vibrate.
    Last edited by Toolmaker51; Feb 17, 2021 at 06:52 PM. Reason: Can two violists to play in tune with each other? Only if one asked to leave.
  11. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Tuomas (Feb 18, 2021)
  12. #8
    Jyväskylä Finland
    Tuomas's Tools
    Yep. Anvil or stand has no recoil. But sometimes floor or ground has.
    I tried this on top of wooden deck, and sand really helped and reduced bouncing. I don't know if it matters on use, but it doesn't do harm either.
    I'll be back when i have done my own version.
    This one is now shipped.
  13. The Following User Says Thank You to Tuomas For This Useful Post:
    Toolmaker51 (Feb 19, 2021)
