Results 1 to 10 of 14
Thread: Making Soft Copper Washers
    Apr 2017
    UK
    editor@glue-it.com's Tools
    A simple article to take people through my way of making soft copper washers:
    Drill some holes in copper sheet, best to then ream the holes
    Cut them into pieces
    Fit them onto a mandrel in the lathe and clamp them between two washers
    Turn them to size
    Then you just need to deburr them and finally anneal them. Annealing copper is easy, heat it up to dull red and dump them in water
    I then have a soft copper washer that will form a great seal on my steam boiler
  2. The Following 17 Users Say Thank You to editor@glue-it.com For This Useful Post:
    carloski (Mar 25, 2021), clydeman (Mar 24, 2021), delalio (Mar 25, 2021), emu roo (Oct 16, 2024), hemmjo (Mar 24, 2021), Inner (Mar 25, 2021), jackhoying (Mar 24, 2021), Jon (Mar 24, 2021), mwmkravchenko (Mar 25, 2021), NortonDommi (Mar 25, 2021), nova_robotics (Mar 24, 2021), odd one (Mar 28, 2021), Rangi (Mar 24, 2021), rgsparber (Mar 24, 2021), sacco1 (Mar 24, 2021), thevillageinn (Mar 29, 2021), Toolmaker51 (Mar 26, 2021)
    hemmjo's Tools
    I have been "making" copper sheet, perhaps reclaiming is a better word, from old plumbing pipe.
    1/2" copper plumbing pipe opens flat to be about 1 1/2" wide. 3/4"≈ 2 1/4", Obviously if you stumble onto some old 3" DWV pipe, you can get a sheet over 9" wide.
  4. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    NortonDommi (Mar 25, 2021), Toolmaker51 (Mar 26, 2021)
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Quote Originally Posted by editor@glue-it.com View Post
    Dumping copper in water after heating to dull red is not necessary, if left to air cool it will suffice.
  6. The Following User Says Thank You to katy For This Useful Post:
    editor@glue-it.com (Mar 25, 2021)
    Apr 2017
    UK
    Quote Originally Posted by katy View Post
    Hi Katy, agree, air cooling is fine. I dump in water as I'm often in a hurry.....But air cooling afterwards still anneals the copper. Thanks, Nigel
    Supporting Member delalio's Avatar
    Oct 2020
    delalio's Tools
    This is a great set of instructions. I recently made some, using a similar method, but yours turned out beautifully! Think I'll be following your guide next time!
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    "Dumping copper in water after heating to dull red is not necessary, if left to air cool it will suffice." True but dropping into cold water has two benefits. 1: It cools down fast ready for immediate use. 2: Most of the Oxides slough off leaving a clean surface.
    If you wanted to make real nice you could soak in White vinegar for a while to brighten.
  10. The Following User Says Thank You to NortonDommi For This Useful Post:
  11. #7
    Nov 2019
    When copper sheets are hard to find, drilling a penny is fast and cheap! Gov't probably doesn't agree...
  12. #8
    Quote Originally Posted by carloski View Post
    Yes, but if you're in the USA, it must be a pre-1982 penny. Pennies after that date are zinc with a thin copper coating.
  13. #9
    hemmjo's Tools
    The government does not care if you burn your money, drill holes it in, you can do anything you want with it.
    But, as mentioned, if you need copper, you won't find any usable amount in a penny..
  14. #10
    The only thing they object to is alterations for the purpose of passing the coin off as a coin of different value.
    There are numerous numismatic fakes where the date on the coin is altered to make it appear to be the date of a more valued coin. I wonder if that too is a crime in the eyes of the Treasury.
