Results 1 to 10 of 20
Thread: Making A Grooving Tool
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    If you own a Quick Change Tool Post, you are very close to having a nice grooving tool. All you need is a length of broken hacksaw blade and a piece of scrap aluminum bar.
    https://rick.sparber.org/MakingA_GroovingTool.pdf
    Thanks,
    Rick
    Rick
  2. The Following 36 Users Say Thank You to rgsparber For This Useful Post:
    albertq (May 18, 2024), Altair (Dec 7, 2018), aphilipmarcou (Dec 6, 2018), Baddog (Apr 18, 2021), baja (Jun 27, 2023), basil3w (Dec 6, 2018), Big-Pete (Apr 17, 2021), davesrepair (Jan 16, 2024), Floradawg (Jan 16, 2024), Frontier Forge (Dec 6, 2018), high-side (Dec 6, 2018), Home-PC (Apr 16, 2021), j.bickley (Dec 6, 2018), johnsmachines (Dec 6, 2018), Jon (Dec 5, 2018), Kevic (Dec 6, 2018), LMMasterMariner (Dec 7, 2018), MasterMaker (Dec 8, 2018), Miloslav (Dec 17, 2018), mklotz (Dec 5, 2018), Moldyjim (Apr 20, 2021), mr mikey (May 18, 2024), nova_robotics (Apr 16, 2021), oldpastit (Dec 6, 2018), Paul Jones (Dec 9, 2018), PJs (Dec 7, 2018), retired-sar (May 18, 2024), rossbotics (Dec 6, 2018), saintrain (Dec 8, 2018), Saltfever (Apr 25, 2021), Seedtick (Dec 6, 2018), Sleykin (Dec 8, 2018), tenncf (Aug 12, 2023), Tonyg (Dec 7, 2018), uv8452 (May 18, 2024), Zaakoc (Dec 6, 2018)
    Now that is very clever. Gotta remember that one. Thanks, Rick.
  4. The Following User Says Thank You to mklotz For This Useful Post:
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Thanks Marv
    Rick
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks Rick, that will work great for small snap rings - o-rings, sure will beat grinding one from a solid bit
    Doug
    Comments are always welcome
    Doug
    Clifford's Avatar
    Jan 2016
    Got that one filed away for another tool in the arsenal, Thanks
    Apr 2016
    Centurion, South Africa
    Great idea Rick. Your choice of mounting the blade tooth side up was also great as hacksaw blades are generally differentially tempered.
  9. #7
    2 great ideas in one: very slick improvised grooving tool, and "if you can't solve the problem, change the problem".
    thanks, Rick!
  10. #8
    Nov 2015
    Italy
    rendoman's Tools
    Nice idea!
  11. #9
    Sep 2013
    Karl_H's Tools
    How do you "lop off" hacksaw blades?
    It seems that you would have to temper it but then you lose the hardness in your cutter.
    It appears you put some heat to the smooth side. Was that to lop or to put in the relief?
    Thanks.
  12. The Following 2 Users Say Thank You to Karl_H For This Useful Post:
    Ralphxyz (May 18, 2024), Sleykin (Dec 8, 2018)
  13. #10
    Thanks Rick! We've added your Grooving Tool to our Machining category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
