Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Making Boxes from PVC Sewer Pipe
    Aug 2016
    wizard69's Tools
    Another fantastic post from Rick. This makes me wonder about the possibility of blow molding softened PVC. Basically use an outside form instead of an inside.
  2. The Following User Says Thank You to wizard69 For This Useful Post:
    nova_robotics (Apr 30, 2021)
  3. #12
    MasterMaker's Avatar
    Aug 2012
    For storage large plastic cable-channel also works great, just cut it into sections, glue pieces of the lid to the rear of the u-shaped channel piece and use some wood plate(particle-board, old floor laminate(amazing material, and cheap) to make fronts...
    Using a piece of plate in both ends of the channel section allows you to retain the lid and make sliding lid stackable boxes..
  4. #13
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by MasterMaker View Post
    Like this? https://www.alliedelec.com/product/p...E&gclsrc=aw.ds
    I had some PVC rain gutter and tried reforming it into a square U shape. Worked nicely!
    Thanks,
    Rick
    Rick
  5. #14
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I have added a warning at the top of the article. Thanks to nova_robotics and clinton1 for bring this to my attention. I can see that if someone was to use a torch, this could get dangerous very quickly.
    Rick
    Rick
  6. #15
    Apr 2021
    What a great idea. Bin boxes get expensive in hurry. I will Be giving this a try!
  7. #16
    Aug 2012
    Thanks,
    Rick
    Yup, that's the stuff.
    Comes in several different large dimensions from large and square to very wide and shallow, which makes it a lot easier to find a dimension that suits one's particular use.
  8. #17
    Thanks earz! We've added your PVC Inner Coupling to our Miscellaneous category,
    as well as to your builder page: earz's Homemade Tools. Your receipt:
  9. #18
    Thanks earz! We've added your Wireless Charging Mount to our Electronics category,
  10. #19
    Thanks earz! We've added your Tarp Clips to our Miscellaneous category,
  11. #20
    Dec 2018
    PVC and a heat gun - I have modified PVC pipe* for various projects using this technique - and yes, you do need to be careful of fumes produced during the process. I try to do this outside with a fan blowing the fumes away. I am sure the boxes are strong but most of my applications don't require a HD box, so I just buy storage containers from D-Tree 2-3 for $1. Sorry $1.25 now.
    *I modify PVC pipe to make fittings for shop-type vacuums for tools and dust collection purposes. With heat you can adjust the diameter of pipe (+ or -) to conform to your tools or connecting hoses, as required.
