Results 1 to 4 of 4
Thread: Make a set of steel cauls for unbelievable clamping pressure (step by step included)
    Supporting Member Make Things's Avatar
    Dec 2018
    Midwest, USA
    Make Things's Tools
  2. The Following 3 Users Say Thank You to Make Things For This Useful Post:
    Jon (Jun 22, 2023), sossol (Jun 19, 2023), tuchie (Jun 20, 2023)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Maybe I missed it, but why not use the alignment bolts for the clamping force as well? It would require having multiple bolt lengths or changing to threaded rod and two nuts (and washers). Stacking a a nylon washer between two steel ones would make them tighten easily. The nylon washers can take the pressure. I use them under the tuning knobs of my headless basses and guitars, which see well over 100lb of tension per string. It's not as smooth as UHMW, but doesn't mush out when tightened.
    Neil
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Hey Neil
    I tried to keep it as simple as possible. Because of the size, and the area that it's intended to serve, I figured it would be difficult tightening as you'd be bumping into things. Still possible and you had some great ideas to go along with it, just a few thoughts I had when making them.
  5. The Following User Says Thank You to Make Things For This Useful Post:
    sossol (Jun 20, 2023)
    Thanks Make Things! We've added your Steel Cauls to our Workholding category,
    as well as to your builder page: Make Things's Homemade Tools. Your receipt:
