Results 1 to 5 of 5
Thread: Make An Electric Crane Combine Forklift
    Supporting Member Kwandotechnic's Avatar
    Apr 2019
    Kwandotechnic's Tools
    Dear you all,
    Today I would like to introduce how to Make An Electric Crane - Forklift Using Battery Powered.
    This Lifter has max capacity 200 kg and up to 120 cm.
    I hope you all feel interested in my video.
    Please like and subscribe to watch new videos!
    Thank you so much!
  2. The Following 3 Users Say Thank You to Kwandotechnic For This Useful Post:
    Biggus1942 (Jul 13, 2021), Jon (Jul 12, 2021), NortonDommi (Jul 12, 2021)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Excellent build, a mini 'Microcrane':
    Looks like you have a enough workshop space to need it.
    Another more compact one I'd love to have is the Machinex PHT-140:
    There is no question about it these little portable cranes are super handy on perfectly flat smooth surfaces. But even with a perfect floor surface the small diameter of the wheel are a detriment when having to move and position the crane while loaded with very much load.
    A good example of this is to try and roll a 2 ton rated engine crane around with just 500 lbs hanging from the hook on a chain. Over coming the rolling resistance can be a challenge even on the best of floors . Something as small as a 6-32 nut will stop you cold in your tracks with 3" wheels increase the load to 1000 lbs and a 1/4-20 will do the same thing with 5 inch wheels with 3000 lbs a 1/2" bolt 1" long will stop anything short of 12" diameter pneumatic tires.
    it doesn't have to be any foreign debris to stop small hard wheels it can be a simple expansion joint in the floor or pavement or a grouted tile joint when it comes to small wheels
    Kwandotechnic (Jul 13, 2021)
    Jul 2014
    NortonDommi's Tools
    As a skateboarder in the early 1970's when all we had were Bakelite wheels,(Incidentally myself and a friend were the first in NZ to have Polyurethane wheels because his sister was on the commonwealth skating team and we were able to buy a set of trucks from the importer),I understand all too well the dilemma of a small wheel encountering a small obstacle suck as a rock especially at high speed.
    Kwandotechnics wheels look reasonably substantial though for the environment..
    Thanks Kwandotechnic! We've added your Electric Crane to our Cranes category,
    as well as to your builder page: Kwandotechnic's Homemade Tools. Your receipt:
