MAGNETIC WELDING GROUND!
bruce.desertrat (Sep 14, 2021), Home-PC (Sep 17, 2021), kboy0076 (Sep 19, 2021), lassab999 (Sep 15, 2021), nova_robotics (Sep 18, 2021)
Thanks orioncons36! We've added your Magnetic Welding Ground to our Welding category,
as well as to your builder page: orioncons36's Homemade Tools. Your receipt:
Why do you need the threaded rod and the spring? If you remove the spring loaded rod and connect the ground wire directly to the steel flat bar you'll get a better ground. Those neodymium magnets are pressed hard against your workpiece (much harder than the spring loaded threaded rod) and they're good electrical conductors. I think the threaded rod and spring is holding you back.
I have a magnetic ground that's just a mag base with a ground wire hard bolted to it. It works great.
That is an interesting idea. I also wonder what the difference would be if the lead were connected directly to the flat bar. There are several magnetic clamps on the market that do use a spring and there are quite a few that do not. I would assume that on much higher amperages more surface are would be beneficial but for most uses there may not be a difference.
My Youtube Channel:
Projects with Rich - YouTube
