Results 1 to 8 of 8
Thread: Magnetic Holding Blocks
    Supporting Member Canyonman44's Avatar
    Mar 2014
    Hi, might be in the wrong place. Mods feel free to move it. I picked up some magnetic holding blocks. But the magnetism is about gone.
    Can these be "Recharged"? If so, how please.
    Ken
  2. #2
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    If these are the common type with the on off switch, you will have to remove the magnets to recharge them or make an electric horse shoe magnet and with the switch turned on apply DC power to the horse shoe and leave it on long enough to re charge the magnets.
  3. The Following User Says Thank You to Sleykin For This Useful Post:
    Canyonman44 (Feb 6, 2020)
    Mar 2014
    Hi, No these do not have the lever. Would you put the block between the horse shoe legs? Or just on top of the block?
    Thank You BTW! Ken
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    Without the lever you would just charge them like regular magnets. They probably have 2 magnets with a bar across the top to increase pull so you would make a horseshoe electromagnet and put one leg on each magnet. A picture would help...
  6. The Following User Says Thank You to Sleykin For This Useful Post:
    Mar 2014
    Thank You sleykin. They do have what looks like 2 drill marks on one end. I'm thinking those are the magnetic source.
    I do have a rather large rare earth magnet, 3x3x2, you must be really careful with it, can smash fingers! Could that be used?
    Ken
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    Quote Originally Posted by Canyonman44 View Post
    Ken
    Possibly, but without more info I can't tell. Might have to take them apart to charge them. Old computer hard drive magnets might work as they are like a flat horshoe magnet and it makes them a one sided magnet...
  9. #7
    Supporting Member 32Rodder's Avatar
    Sep 2019
    Iowa
    32Rodder's Tools
    Contact K&J Magnetics, Inc. and see if they have a good solution. you can find them on the web by searching the name I noted. Good Luck
  10. The Following User Says Thank You to 32Rodder For This Useful Post:
    Sleykin (Feb 7, 2020)
  11. #8
    Mar 2014
    Thanks 32rodder
    I checked out the K&J web site and came across this;
    (Quote from K&J website)
    Remagnetizing Old Magnets
    Alnico horseshoe and bar magnets can become demagnetized if dropped, stored without a keeper, or by repelling other magnets. Instead of throwing them out, you can remagnetize them using neodymium magnets. Stroke the north pole of a strong neodymium magnet from the center of the alnico magnet to the south pole end of the horseshoe several times. Then, stroke the south pole of the neodymium magnet from the center of the alnico magnet to the north end of the horseshoe several times. This will recharge the worn out alnico magnet. If you reverse the directions, you'll re-magnetize the horseshoe in the opposite orientation! Check out our D4X0-ND to help identify the poles of your neodymium magnet.
    Ken [Don't know why it's in Bold, the menu B wouldn't unlock]
  12. The Following 2 Users Say Thank You to Canyonman44 For This Useful Post:
    Inner (Feb 7, 2020), Sleykin (Feb 7, 2020)
