Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Made a quick test video about angle grinder diamond metal blade.
    Dec 2016
    Ralphxyz's Tools
    Thanks for the reply, I would imagine using a diamond cutoff tool it would get hot.
  2. The Following User Says Thank You to Ralphxyz For This Useful Post:
    Scotsman Hosie (Oct 28, 2019)
  3. #12
    hemmjo's Tools
    We need to be sure that we are talking about the same kind of wheels. This is what I am talking about for cutting steel. https://www.ctemag.com/products/leno...-cutoff-wheels It is diamond, according to this information. The grit is bonded to the rim, it is very course.
    I also have a 4 1/2" diamond blade that the rim is so smooth it will not cut you if you touch it. It cuts brick, concrete, tile, etc very easily. I typically use it wet, but have used it dry if I have to. I would never use it for cutting steel, I have never tried steel with this one, but I know it would be very slow and get very hot.
  4. The Following User Says Thank You to hemmjo For This Useful Post:
