Results 1 to 10 of 11
Thread: Made my engine hoist a little better.
    Jan 2016
    Super 55's Tools
    I didn't like the way the folding legs on my engine hoist tilted back in the up position, so I decided to make a stop so they wouldn't travel so far. The handle also doubles as a handle to move the hoist around the shop. I just welded a small piece of angle iron onto a piece of pipe, then attached it to the bolt that the lift arm pivots on. So, you can put it on or take it off by just undoing one nut. The handles are just $1 rubber handles from a hardware store.
    Made my engine hoist a little better.-img_2715.jpgMade my engine hoist a little better.-img_2716.jpgMade my engine hoist a little better.-img_2717.jpg
  2. The Following 13 Users Say Thank You to Super 55 For This Useful Post:
    57_210 (Mar 5, 2024), asterix (Nov 8, 2022), astroracer (Mar 7, 2016), C-Bag (Feb 15, 2016), emu roo (Nov 20, 2024), Grumpyoldman (Feb 16, 2016), johncg (Nov 8, 2022), Jon (Feb 14, 2016), kbalch (Feb 15, 2016), oldsalt (Mar 11, 2016), Paul Jones (Mar 7, 2016), verticalmurph (Dec 28, 2022), WmRMeyers (Nov 9, 2022)
    May 2012
    Byron, Michigan
    astroracer's Tools
    That does keep the foot print smaller! Good job!
    Mark
    Thanks Super 55! We've added your Engine Hoist Stop to our Jacks and Lifts category,
    as well as to your builder page: Super 55's Homemade Tools. Your receipt:
    Aug 2012
    Australia
    desbromilow's Tools
    I duplicated this idea on my crane - great idea
    I had made exactly the same addition. I also changed the top bolt on the cylinder to a QD pin. I pull the pin for storage and this allows the boom to fold down some more. I had to grind a bit off the mounting tabs to clear the cylinder.
    Mar 2020
    I replaced the hydraulic jack with a battery powered linear actuator (3000 lbs. capacity). Raising and lowering the boom became a breeze.
  8. #7
    Quote Originally Posted by mansworld View Post
    That would be a great improvement but 3000 lbf would not be anywhere near enough for me. I will look for a bigger capacity.
  9. #8
    An interesting feature of certain import products; a collapsible device (for efficient storage) not condensed into smallest foot print?
    Half a dozen individuals make a similar alteration for the same reason, to lessen room consumed of storage.
    So how qualified or experienced can the original designer be? Even looking at the before condition appears a potential high center situation if pushed above waist high from 'front', one little pebble is all it might take.
  10. #9
    Mar 2020
    I was referring to the 1.5 - 2 ton foldable engine hoist pictured in the subject. furthermore, 3000 bls. /1.5 ton was the biggest capacity battery powered linear actuator available at Amazon, and I doubt if you can get any larger capacity than that. One thing you do is to add extra actuators and join them in a group till you reach your target capacity.
  11. #10
    The 1.5 - 2 ton is at the end of the boom. The actuation is way back from that and so through leverage you need several times 1.5 - 2 ton at the actuator to get 1.5 - 2 ton at the hook. Using a 3000 lbf actuator may give you a useful tool but it will not give you 3000 lbf where it matters.
