Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Made my engine hoist a little better.
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by mansworld View Post
    I replaced the hydraulic jack with a battery powered linear actuator (3000 lbs. capacity). Raising and lowering the boom became a breeze.
    just be aware that you've considerably reduced the capacity of the crane - most of the engine cranes use a 9T hydraulic ram, to alllow 2T at the short extension (no extension), and 500kg (1/2T) at max extension - by using a 3000lb ram, you've scaled your capacities by a similar factor (3,000lb is nearly 1.5T which is 1/6 of 9T, which means your capacity of no extension reduces from 2T to 2t/6, and your max extension capacity of 500kg (1/2T reduces to 1/2t divided by 1/6 = 1/12t which is about 80kg (call it 160 lbs)
  2. #12
    dgbreggin's Tools
    I replaced the ram on mine with an air powered version.
