Results 1 to 10 of 12
Thread: Low Impact, Dual Purpose Hammer Build
    Supporting Member Make Things's Avatar
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Download plans for hammers.
  2. The Following 11 Users Say Thank You to Make Things For This Useful Post:
    butlerandrew (Jan 9, 2024), Christophe Mineau (Jan 13, 2024), Inner (Jan 14, 2024), Jon (Jan 8, 2024), mr mikey (Jan 9, 2024), nova_robotics (Jan 9, 2024), olderdan (Jan 8, 2024), Ralphxyz (Jan 9, 2024), rlm98253 (Jan 8, 2024), Tule (Jan 9, 2024), whitebear (Jan 9, 2024)
    Thanks Make Things! We've added your Hammer to our Hammers category,
    as well as to your builder page: Make Things's Homemade Tools. Your receipt:
    Lovely work indeed. Be proud; very proud.
    Supporting Member drivermark's Avatar
    Oregon City, Or. USA
    That looks way too pretty to be used as a whacking utensil.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Since the grade 8 bolt can be cut with a hacksaw, why use an angle grinder on the lathe? Wouldn't a HSS cutter do a more precise and faster job? Besides, grinding dust on lathe ways is not good.
    Rick
    Rick
  7. The Following User Says Thank You to rgsparber For This Useful Post:
    uv8452 (Jan 13, 2024)
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Rick
    Do you know of any HSS cutter tools I can use with a woodworking lathe? The cutting with the disk cut at the same rate off the lathe as it did with it, so why is the dust any different?
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Sorry, my mistake- I didn’t notice you had chucked up the bolt in a wood turning lathe.
    I do suggest you cover your ways with a cloth when grinding.
    Rick
    Rick
  10. The Following User Says Thank You to rgsparber For This Useful Post:
  11. #8
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Rick
    No problem...I'm just using what I have. When you said "Ways", did spellcheck magically change it from face?
  12. #9
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Cover the ways with a cloth. Your tailstock rides on the lathe’s ways. That grinding grit is bad.
    Rick
    Rick
  13. The Following User Says Thank You to rgsparber For This Useful Post:
  14. #10
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Never heard of the term 'lathe ways'. I learned something today...thanks.
