Results 1 to 7 of 7
Thread: Long Boring Head
    Supporting Member Canobi's Avatar
    Mar 2016
    Shrewsbury, Shropshire (UK)
    Canobi's Tools
    Long Boring Head
    Hi folks
    So my workshop is finally equipped enough to get a start on making the things I put it together for. Unfortunately, my small lathe's toolpost won't take boring bars with the kind of girth I'd like, so I opted to make a long boring head I can use in my ER32 collet chucks:
    The head is nothing special and was a simple turning job, though the finish on the head might make one or two of you wince a little but was done on purpose for artistic flair. I'veworks copper and did a fair amount of smithing in my youth and surface texture has always been an interest of mine. It occured to me while turning the head that it wasn't a critical surface so thought I'd see what controlled chatter could do. Though it's a bit uneven as I was testing it out for the first time.
    Canobi
    It's not the destination but the journey you take to get there that matters.
  2. The Following 6 Users Say Thank You to Canobi For This Useful Post:
    JRock (Apr 25, 2018), Miloslav (Dec 17, 2018), PJs (Apr 28, 2018), rossbotics (Apr 26, 2018), Seedtick (Apr 25, 2018), Sleykin (Apr 26, 2018)
    Feb 2015
    I prefer girth over length myself, also.
    Dec 2014
    Gone
    This thread is boring.
    You'll wind up with a lot of these. Most used are thru-hole as what you present here, along with flat bottom, and recessing. With correct bits they'll do more than bore; threading, snap and O-ring grooves, undercutting, etc.
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Apr 28, 2018)
    Thanks Canobi! We've added your Long Boring Bar to our Machining category,
    as well as to your builder page: Canobi's Homemade Tools. Your receipt:
    Mar 2016
    Canobi's Tools
    I hadn't considered using one for those operations, thanks for the tip
  9. The Following User Says Thank You to Canobi For This Useful Post:
    PJs (Apr 28, 2018)
  10. #7
    Mar 2016
    Canobi's Tools
    Hi folks
    I finally gave the tool a good test run. I used it to cut a radial slot in a part for my next build project (a keyway slotting attachment). I ground a new egde on the other side of the bit too as the original profile is far more suited to cutting internal grooves (as mentioned by toolmaker51).
    The new profile needed a regrind, my initial tast was on aluminium and it worked amazingly but the radii was too big for steel. It also took me a while to find the right feed n speed for the tool. I was treating it like a fly cutter at first and had been cranking the carriage leadscrew by hand, being that it only has one tooth but discovered I've actually made a real metal munching monster, which is only limited by my small lathes meagre capability.
    New profile prior to regrind:
    Initial test cut in alu:
  11. The Following 4 Users Say Thank You to Canobi For This Useful Post:
    Corm (Jun 5, 2018), mwmkravchenko (Jun 6, 2018), PJs (Jun 6, 2018), Seedtick (Jun 5, 2018)
