Results 1 to 4 of 4
Thread: LIFTING AND PULLING MACHINE FOR 150 KG WEIGHT.
    India
    Arrow LIFTING AND PULLING MACHINE FOR 150 KG WEIGHT.
    Need some help to build a machine for lifting and pulling of weight 1000 kg approx.
  2. #2
    California, central coast
    C-Bag's Tools
    Lifting and pulling what? It's hard to make suggestions with no info on job.
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    worm gear is one of the solutions.
  4. #4
    Quote Originally Posted by RAHUL JHA View Post
    Equivalent 2200 lbs. If movement of the load is involved, there are complications. Pure lifting is easy enough with a ratchet or chain lift hung from an A frame. Question remains what you mean by 'pulling'. Lowering mass onto a skid and pulling with an off-road winch is very commonplace. Main issues are anchor point, distance and whether an incline is involved.
    Think like ancient Egyptian, Roman or Grecian. If I can get a 2500lb bandsaw on my tilt bed trailer, (two separate machines and occasions, I like bandsaws) by myself anybody can. Used two speed manual boat trailer winch loaded with tow strap, wooden peeler cores as rollers. Built a winch mount on receiver hitch for my little 4wd truck. Detach trailer, chock trailer wheels, move vehicle forward about 8 feet, park in neutral and chock it as well. This benefits catenary effect (lowers pull effort parallel to ground). Pay out winch strap and attach. Pry machine up for first roller, [nice with an assistant to keep the rollers fed from the front], start cranking and watch reaction of onlookers.
