Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: leadscrew protection
  1. #21
    Apr 2016
    make sure when you tighten the rear lead screw support that it is aligned. and watch the screw when you engauge it to see if it moves so you can farther better align it it. I havent decided on just how I will put covers on my 9x20. but I do have central vac system I made to clean my machines fast&easy, it works great. I also need to make way covers. I had made one for the cross slide. it worked for a while but made it by hand and didn't preform as I wanted it to do,I need to go to my brothers and use his box&pan break to make a real one...some day...
    Download plans for lathes.
  2. #22
    Elizabeth Greene's Tools
    This is a very well timed post. I've been trying to make a 3-D printable leadscrew cover for my chinese mini lathe. I wonder if I could print a springy thing like you have here.
  3. #23
    Apr 2016
    Im still thinken about just buy a bellows for mine. but as little as I use either lathe nowdays...the next owner might get to do that after I die.
  4. #24
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by Elizabeth Greene View Post
    That would be great if you could, 3d stuff is getting more advanced but figuring out spring tension might be a bit of a hurdle.
  5. #25
    Jun 2018
    Stevohdee's Tools
    Or gaffer tape an old sock over it haha
  6. #26
    Apr 2016
    Ill pass on the tape & sock.
