Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 10 of 53
Thread: Laying perfect bricks like dominoes - GIF
    The real secrets of the Freemasons. Wait for it, it ends perfectly.
    Brick laying machine GIF
    Pavement brick laying machine GIF
  2. The Following 8 Users Say Thank You to Jon For This Useful Post:
    bimmer1980 (Sep 20, 2018), dubbby (May 20, 2020), KustomsbyKent (Sep 11, 2018), Miloslav (Dec 5, 2018), Moby Duck (Sep 17, 2017), Saxon Violence (Sep 11, 2018), Scotsman Hosie (Feb 23, 2019), Seedtick (Aug 12, 2017)
    Jul 2015
    Sheesh! How'd they do that?
    SRQSid's Avatar
    Sep 2013
    The last cap landed flat which allowed the one behind it to lay flat, etc., etc.,etc.....
  5. The Following User Says Thank You to SRQSid For This Useful Post:
    These "mysteries" never seem to last as long on this website as on others.
    Here's a screenshot from an explainer video, at the critical moment, as the domino effect doubles back.
    And here's an explanatory diagram:
  7. The Following 3 Users Say Thank You to Jon For This Useful Post:
    Moby Duck (Sep 17, 2017), Scotsman Hosie (May 23, 2019), Seedtick (Aug 12, 2017)
    Jan 2016
    Moby Duck's Tools
    Amazing, but I think that the real trick will be how are they going to get the mortar, under and in between, those capping bricks.
  9. The Following User Says Thank You to Moby Duck For This Useful Post:
  10. #6
    You're not supposed to ask questions like that you are just supposed to be amassed.
    But to let you in on a little secrete before setting up the cap bricks you would have put down a thin layer of mortar which would have had an epoxy resin mix in it then stacked the bricks as in the video. domino-ed them then point trowel and cake decorator-ed any additional thin set between them tap them into final place with the but of the trowel handle gauged them with a set level
    there would be 2 extremely tricky parts to the process first every brick would have to be stood in exactly the right place easily done with a wooden gauge cut the correct length. The other would be overcoming the surface tension or the mortar on the ends of the bricks as they were knocked over, probably not too difficult as long as the resin in the mortar had not started to react.
  11. #7
    More nice bricklaying. And I believe these are actual bricks, laid around a central frame.
  12. The Following 4 Users Say Thank You to Jon For This Useful Post:
    KustomsbyKent (Sep 11, 2018), PJs (Sep 10, 2018), Saxon Violence (Sep 11, 2018), Scotsman Hosie (May 23, 2019)
  13. #8
    What a nightmare that must have been for the brick layer trying to please the architect or builder
  14. The Following User Says Thank You to Frank S For This Useful Post:
    greyhoundollie (Jul 12, 2019)
  15. #9
    Jul 2016
    And feather in the cap of the mason!!!
    Talk about a resume!!
    Eric
  16. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Stunning masonry! Wow!
    Mark Twain
