Thread: Lathe Tailstock Alignment Tool Demo Wood or Metal Lathe
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Cool Lathe Tailstock Alignment Tool Demo Wood or Metal Lathe
    This is a demonstration of a tool I made and posted on the Forum "Homemade Tools. Net".
    This is a Lathe Tailstock Alignment tool for use on Wood or Metal Lathes. Tailstock alignment is very important if you do not wish to turn a taper in your work piece. This tool can make quick work of alignment of the tailstock to the center of rotation of the spindle. Just to note you want to use a know round straight piece in your chuck to referance to, the use of a Endmill or 1/2 or larger drill bit are good to use.
    Video Link:
    Link to Build on Homemade Tools. Net. My builder name is "Catfish".
    Http://www.homemadetools.net
    Please Subscribe: https://www.youtube.com/channel/UCme...view_as=public
    To support the channel Pick up a Dovetail Cutter and Scribe.
    Info: Email To: RRINTHESHOP@GMAIL.COM
    Follow me On Instagram: https://instagram.com/rrintheshop/
    Visit me on You Tube for many tool making videos.
    Link: https://www.youtube.com/user/Catfish6945
  2. The Following 3 Users Say Thank You to Catfish For This Useful Post:
    Altair (Aug 11, 2019), high-side (Aug 12, 2019), HUMARIA (Aug 13, 2019)
    Randy's original post of his Lathe Tailstock Alignment Tool can be found here: Lathe Tail Stock Alignment Tool
    Thanks for the demo, Randy!
  4. The Following User Says Thank You to Altair For This Useful Post:
    Jon (Aug 15, 2019)
    Stockholm, Sweden...
    DIYSwede's Tools
    Thanks for posting, Randy!
    There are a few caveats in using this method regarding indicator sag which the following post clarifies:
    http://www.homemadetools.net/forum/t...4-3#post133360
    Short story for the Perfectionists: The chuck-mounted axle, arm and the indicator itself should ideally be absolutely rigid,
    while also being mass-less to avoid gravity sag, and to be optimally consistent.
    -Myself, I can buy the small errors while checking my chinese 7 x 14".
    Two cents
    Cheers, Johan
  6. The Following User Says Thank You to DIYSwede For This Useful Post:
    Catfish (Aug 13, 2019)
