Thread: Lathe Cross slide glass scale DRO installation
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    By the way, I didn't think I would show that, there are so much information available about that, but as I was to disassemble it, I took some pictures, so here they are, for the record.
    My lathe is a 10x30 inch, so 250mm x 750 mm.
    There is really no much room to install the scale, and I had to grind a channel through the back slide of the carriage to make room to the wire to go out on the rear side.
    I made a thick aluminum plate to screw the scale on, and I milled some recess for the gib adjustment set screws to fit into.
    And eventually, the cap was made using the aluminum angled profile originally provided with the glass scale, but I had to cut it along its length in order to reduce its size to the minimum.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 5 Users Say Thank You to Christophe Mineau For This Useful Post:
    asterix (Nov 26, 2021), DIYSwede (Nov 26, 2021), Jon (Dec 1, 2021), LMMasterMariner (Nov 26, 2021), Tonyg (Nov 27, 2021)
    Thanks Christophe Mineau! We've added your Glass DRO Cross Slide Mount to our Lathe Accessories category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Apr 2016
    nice work! I had thought about mounting under the carrage on my 9x20 pos enco ( got it just 2 weeks before they closed up) or possiably put a electronic scale on it.
