Results 1 to 10 of 11
Thread: Lantern pin vise
    Lantern pin vise
    It's impossible to securely grip a bolt, or anything shaped like a bolt, securely in a conventional lathe chuck with the head end of the bolt in the chuck jaws. This difficulty led to the creation of something called a lantern chuck which provides a recess to accommodate the larger diameter portion.
    I've often thought that it would be handy to have a hand vise that had the same feature for holding bolt-shaped objects. I made a trial version from aluminum...
    because, at the time, I didn't have any suitable steel. This isn't something one uses very often so the softer metal hasn't been a problem; besides, it prevents marring the workpiece.
  2. The Following 11 Users Say Thank You to mklotz For This Useful Post:
    baja (Jul 17, 2020), Big-Pete (Jul 17, 2020), Captainleeward (Feb 1, 2018), emu roo (May 1, 2024), high-side (Jul 23, 2020), jjr2001 (Feb 2, 2017), Moby Duck (Feb 1, 2017), Paul Jones (Feb 2, 2017), PJs (Feb 2, 2017), Seedtick (Feb 2, 2017), Toolmaker51 (Feb 2, 2017)
    California, central coast
    C-Bag's Tools
    Interesting idea. Did you cut a longitudinal v in the jaws?
    I'm often having to shorten bolts and screws and this looks like a good basis for what I need. I also think I'd do away with the thumb wheel and either use an Allen head or a screw the other one on your vise so it could lay flat on the bandsaw table I usually end up using.
    Thanks for sharing.
  4. The Following 5 Users Say Thank You to C-Bag For This Useful Post:
    Captainleeward (Feb 1, 2018), jjr2001 (Feb 2, 2017), Moby Duck (Feb 1, 2017), Paul Jones (Feb 2, 2017), PJs (Feb 2, 2017)
    Thanks for sharing.
    No, I didn't but only because I never got a round toit. It's a simple job and I'll do it the next time I have the mill set up to cut V-grooves. So far I've only used it on small non-cylindrical parts.
    Thanks mklotz! We've added your Lantern Pin Vise to our Vises category,
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Marv,
    I am always impressed by your ingenuity. Thank for sharing this handy tool and also thanks to C-Bag for the suggestion for laying the vice flat. I will be making one these in a similar style to your vise and in aluminum.
    Regards, Paul
  8. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    C-Bag (Feb 2, 2017), PJs (Feb 2, 2017)
    C-Bag's Tools
    Marv,
    Regards, Paul
    Yes, a deep bow to your vast knowledge and expertise Marv. I have learned so much from your posts. Especially nomenclature.
    I'd never heard of the term pin vise before one of your past posts, now a lantern pin vise. Is that because of the hole for head of the bolt? I'd always seen lantern style referred to on some lathe tool posts and never thought about it thinking is was just an obscure reference. But I guess if it didn't have the tool holder in it, it would resemble an old lantern. But I almost never saw them without a tool holder in them.
  10. #7
    I'd never heard of the term pin vise before one of your past posts, now a lantern pin vise. Is that because of the hole for head of the bolt? I'd always seen lantern style referred to on some lathe tool posts and never thought about it thinking is was just an obscure http://www.homemadetools.net/forum/l...85772reference. But I guess if it didn't have the tool holder in it, it would resemble an old lantern. But I almost never saw them without a tool holder in them.
    Lantern in this usage refers to anything that sort of looks like a lantern. A "lantern" tool post has a sort of cartouche-shaped opening into which one inserts the lathe tool. Viewed conceptually, it looks a bit like an antique lantern, the hole representing the "window" through which the candle flame was seen.
    Jump forward to modern times (well the early 20th century) and a lathe chuck with a window to accept mushroom-headed parts comes to be called a "lantern" chuck. See this post...
    http://www.homemadetools.net/forum/m...l-screws-26214
    for my version of same for machining the ends of screws.
    As you surmised, I carried the nomenclature over to this pin vise because it accommodates the handling of mushroom parts.
    Nothing sacred about the name; if it looked as if it had grown underground, I would have called it the truffle pin vise. :-)
  11. #8
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Thanks Marv, yet another thing in the to do list !
    Cheers !
    Christophe
    Facebook : La Belle Note
  12. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Captainleeward (Feb 2, 2018)
  13. #9
    Oct 2012
    Marv
    I'll never get caught up. I like it enough to go and build one.
    Nelson
  14. #10
    Jul 2016
    Thanks for the lantern derivation question, iv been wondering. Thanks for the answer.
    Eric
