Knurling a knob using a tap.
Knurling with a threading tool - video
Knurling from two sides - GIF
Universal cut knurling tool - video
CNC knurling stainless steel - GIF
Knurling a shaft - GIF
New plans added on 01/13/2025: Click here for 2,698 plans for homemade tools.
Looks more like hobbing a worm gear using a tap. When using this procedure to make worm gears it is better to cut a grove around the center of the blank then start the gear cutting process at the end of the taper on the tap This will preselect the pitch diameter and final depth of cut as the gear rotates and the start of the tooth profile is exposed you move the gear blank towards the main body of the tap will make cleaner teeth and will not be recutting a tooth
Doing it the way it was shown in the video at least 1 tooth is removed by the time full depth is achieved
greenie (May 22, 2023), KustomsbyKent (May 22, 2023), odd one (May 28, 2023)
