Results 1 to 9 of 9
Thread: Killing yellow jackets using gasoline - GIF
    nova_robotics (Mar 24, 2024), Ralphxyz (Mar 24, 2024)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    It is amazing how quickly those yellow jackets die from exposure to gasoline fumes. Take this also as a cautionary tale when you are handling gas in a poorly ventilated space.
    Rick
    Rick
  4. The Following User Says Thank You to rgsparber For This Useful Post:
    Aug 2020
    fool injector's Tools
    Try 91% or 99% rubbing alcohol. Less flammable, less stink, water soluble, and no residue. About as fast.
  6. The Following User Says Thank You to fool injector For This Useful Post:
    bob_3000 (Mar 24, 2024)
    Sep 2018
    nova_robotics's Tools
    That's absolutely amazing. I've used dish soap and water a few times, which works very well. But this gasoline trick is much better.
    meyer77's Avatar
    Feb 2019
    The fire danger is far worse than the yellow jackets!
    Jun 2017
    I keep a spray can of non-Chlorinated brake clean on my work van to deal with cleaning & bug control. Gives me a nice bit of standoff from the target. I was out of bug spray one time &came across a wasp nest & used spray contact adhesive that's used to attach plastic drywall bead. That stuff makes you feel like spiderman shooting out webs.
  10. #7
    Apr 2012
    NorCal
    Saltfever's Tools
    Isopropyl 99%, as mentioned above, is just as fast and a much safer. Isopropyl (or ethanol) were a major ingredient in the Covid disinfectant formula and is quite inexpensive. No experience with ethanol on wasps . . . only myself.
  11. #8
    Dec 2022
    Midwest US
    ductape's Tools
    The glass jar was a good idea. Gasoline in a plastic cup may be problematic, but it seems to work for this. Also, those look like paper wasps, not yellow jackets. The former is fairly docile for what they are, but the latter would have one on the ground crying for help before getting anywhere near the nest in broad daylight like this.
  12. #9
    Mar 2018
    It works fine as long as one doesn't come BACK to the nest while you have it covered. I guess one sting is better than several though.
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
