Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Irrigation Flow System
  1. #21
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    PJ,
    The one thing I am positive about in all of this is that a patent IS impossible for anyone to get on this work. I have already defensively published it so now the flow monitor and control is in the public domain. It would be like trying to patent the wheel.
    As for the circuit, I expect that the product would be all SMT and not use the Pro Micro at all. Really not a big deal. I wish I could say the same for the flow meter. It must be accurate over a wide range of flow rates yet be low cost. A turbine based flow meter isn't going to cut it. Might have to approach Badger and have them make a special version with a pulse output. They make some that way but the closest I could see was one pulse per gallon. I need about one pulse per 0.03 gallons. That comes out to one pulse per rotation of the nutating disk. The magnetic pick up must be Hall Effect because a reed switch can't keep up nor have the longevity. Fortunately, the body of the meter would not need to be modified.
    Rick
  2. #22
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Rick,
    My professional experience in flow measurement & control is with Mass flow (DP/SP/temp), thermal mass flow and velocity for gasses and particulates. As I indicated before I thought your flow measurement could be done with Mass flow or Ultrasonic. Converting either to pulse output would result in a loss of all the accuracy and possibilities for control they offer.
    I do still think that ultrasonic would do a lot for your system but would require considerable changes to your input and likely the code. This also assumes you are using city drinking water that has a good/relatively constant conductivity for the low flow rates.
    The only other possibilities I see is a Mag Meter front end and it's also non invasive, which could be converted to pulses but would require some coils, additional power/circuits to read them and some messing around with calibration then convert that to a pulse through some kind of circuit...a comparator/inverter to (74LS121) monostable multivibrator or a couple of nor gates and RC, maybe??
    The links have good +/- write ups. Also ran across this white paper on a unique Mass Flow measurement.
    Not sure what type of prox sensor you tried but would think that would work. There are three basic types inductive, capacitive & magnetic in 4 flavors NPN/PNP/NO/NC....
    I also took a look at the Hunter offerings and they have some nice features at reasonable prices, including 2 wire pulsed output and their controllers have wifi for decent costs I thought based on features.
    Other than that, getting Badger to build it in based on your design is a plausible direction??
    Best of luck with where ever you take this. ~PJ
  3. The Following User Says Thank You to PJs For This Useful Post:
    Paul Jones (Jan 4, 2018)
  4. #23
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Rick,
    Picking the best flow meter is part of turning my proof of concept into a real product. However,
    I have contacted Badger about a modified meter. My hope is that they will see it as a new market.
    The Arduino does have a decent analog to digital converter so a flow meter with an analog output could be made to work just fine.
    The proximity sensor I tried is inductive with an NPN output. I use them on my CNC mill with good results so it really surprised me that I could not find a sweet spot on the top of the Badger meter. I did use a small magnet to map out the structure of the steel. Also tried iron filings to prove to myself there was no magnet in there.
    Rick
    Rick
  5. #24
    Thanks Rick! We've added your Irrigation Flow System to our Farm and Garden category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
