Results 1 to 7 of 7
Thread: Instant Vise Alignment
    Supporting Member Lets Roger That's Avatar
    Apr 2022
    Canada
    Lets Roger That's Tools
    Hi folks,
    I created a 4 step process to make my milling machine vise align within 0.001" every time even before bolting it down. After the initial work, all I need to do is install my vise and I'm done.
    Hope this helps someone from ripping their hair out.
    Take care
    Gilles
  2. The Following 8 Users Say Thank You to Lets Roger That For This Useful Post:
    greenie (Jun 22, 2023), Inner (Jun 22, 2023), Jon (Jul 5, 2023), mr mikey (Jun 23, 2023), nova_robotics (Jun 24, 2023), piper184 (Jun 24, 2023), Sleykin (Jun 25, 2023), Toolmaker51 (Jun 22, 2023)
    Creative system and approach, but a really common feature of milling vises are cuts underneath to mount fixture keys, many for jaws parallel or perpendicular to main axis of travel, the "X". That's what drill press vises lack.
    That said, many find keys and fit to slot troublesome. Keys, being hardened, also raise concern about marring the table. Your idea curtails that too.
    So, only real suggestion is milling the vise slots, (over filing) in accordance with stationary vise jaw.
    For that, I'd clamp a good straight bar down, flip the vise, clamp securely to bar, and use DRO and/ or indicator to ascertain "Y" position.
  4. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    greenie (Jun 22, 2023), mwmkravchenko (Jul 9, 2023)
    Dialing in or 'clocking' a vise without suggestions above, by OP or myself, is worth another or perhaps alternate tip.
    Initially, don't run indicator all the way across stationary jaw. Place un-keyed vise, step to one side of table and sight the jaws and slots into visual parallel.
    Mount indicator, touch off, wind X axis about 1/2 way across jaw. If reading remains .000, continue across, if satisfactory 0 holds, you're done. It happens!
    Moving halfway across, detecting variance tells you one half the amount total. Close enough to predict amount of correction needed. You can often finish in one lap, verifying on return.
  6. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    Bummers (Jul 10, 2023), mwmkravchenko (Jul 9, 2023), uv8452 (Jul 10, 2023)
    Congratulations Lets Roger That - your vise alignment method is the Tool Tip of the Month for June 2023!
    This is a well thought-out procedure that will save people a lot of time and grief.
    Some more nice tool tips from June:
    Coin Cell Tips by mklotz
    Table Saw Blade Teeth Zeroing by Make Things
    End Grain Fastening by Make Things
    Square Holes in Plastic Planks by rgsparber
    Making Your Own Tracks by Make Things
    Handyman Secrets by AB-SHOP
    Planing Stop Appliance by Make Things
    Adding Armor to Your Tool Rest by Make Things
    Lets Roger That - we've added your Tool Tip to our All Tool Tips of the Month winners post. And, you'll now notice the tool tip award in the awards showcase in your postbit, visible beneath your username:
    And, you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    Congrats again
    Supporting Member flyfr8rs's Avatar
    Mar 2016
    Alaska
    A nice way to do it, but once I discovered this method,
    , I've never looked back. Literally 30 seconds or less to a half thou, and you don't need to modify or create anything. I've shown this to other machinist friends and they agree its dead simple. Just another way to do it.
  9. The Following 7 Users Say Thank You to flyfr8rs For This Useful Post:
    brianhw (Jul 11, 2023), carl blum (Jul 10, 2023), johncg (Jul 10, 2023), mwmkravchenko (Jul 9, 2023), nova_robotics (Jul 10, 2023), piper184 (Jul 11, 2023), rgsparber (Jul 10, 2023)
  10. #6
    Sep 2018
    nova_robotics's Tools
    Quote Originally Posted by flyfr8rs View Post
    A nice way to do it, but once I discovered this method, I've never looked back. Literally 30 seconds or less to a half thou, and you don't need to modify or create anything. I've shown this to other machinist friends and they agree its dead simple. Just another way to do it.
    That's a pretty ingenious trick. I wish I had a power feed.
  11. #7
    Berkshire UK
    thehomeengineer's Tools
    Hi
    I hope you don't mind me adding a couple of links to this post which I added to HMT a while back in 2018. This may also help align vices and other tooling on a mill. This method also works for positioning components on rotary tables, alignment of angle plates and any other tooling that needs to be clamped parallel to an axis.
    The quickest way I know how to clock up a machine vice
    I also use dogs as suggested by toolmaker51 and have also added a link on this subject Machine dogs, simple to make and use.
    I hope you find the links of interest and thank you for posting your method for vice alignment.
    The Home Engineer
  12. The Following User Says Thank You to thehomeengineer For This Useful Post:
    ductape (Jul 11, 2023)
