Thread: Installing Power Strips with Multiple Keyhole slots
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    The power strip I just mounted on the wall has keyhole slots to anchor it.
    It didn't take any talent to drive a screw in the wall for the first keyhole. But how do I do the second one so it is in the right location?
    My trick was to take a flat head 6-32 screw with a nut and slide it into the second keyhole. Then I finger tightened the nut so it did not slide around. With the power strip resting on the narrow end of one keyhole on the first screw, I positioned the power strip at the desired orientation. Then I firmly pushed it against the wall. The 6-32 screw made a nice, clean depression in the drywall. It was then a matter of driving in the second screw into this depression. Of course, it has to align.
    Rick
    Rick
  2. #2
    Some random thoughts on the subject...
    I'm not a woodworker but long ago I bought one of their tools - a set of (blind) hole transfer punches, e.g.,
    https://www.amazon.com/AUTOTOOLHOME-...s%2C113&sr=8-9
    I couldn't tell you how often they've come in handy around the house. If mounting multiples, they can be used to generate a cardboard template that can be used directly on the wall.
    If one sets a compass to the distance between the holes then swinging an arc from the first marked hole will show all the locations on the wall that preserve that distance. Unfortunately, I can't think of a simple, clever way to determine the point on the arc that provides the desired orientation of the power strip.
  3. #3
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Transfer punches do look like very useful tools and would be easy to make.
    Thanks,
    Rick
    Rick
