Installing a hex rivet nut.
Squeezing a rivnut - GIF
Hot riveting up close - GIF
Orbital riveting machine - GIF
Pneumatic rivet buster - GIF
Chinese rivet manufacturing process - GIFs
desbromilow (Oct 17, 2023), kboy0076 (Oct 22, 2023), KustomsbyKent (Oct 19, 2023), nova_robotics (Oct 17, 2023), Ralphxyz (Oct 21, 2023)
Pretty cool!
Insert jaws
Spread jaws open
PULL jaws back (like a single-tooth broach) and t cuts the hex
Insert rivnut
Insert screw-puller into rivnut
Tightenrivut into place
DONE!
Charles Waugh
www.charleswaugh.com
Okay I did some digging. Looks like a couple companies offer hex rivnuts. Rivnut USA and Sherex, maybe other manufacturers but those are the only two I found. The tool to create the hex hole is not provided by either of those companies. The hex hole tool appears to be made by a company called Avdel? Maybe? I can't find any details, but here's a video of what I believe is the same tool in operation.
Altair (Oct 19, 2023), astroscuba (Oct 18, 2023), Inflight (Oct 21, 2023), Inner (Oct 21, 2023), KustomsbyKent (Oct 19, 2023), Ralphxyz (Oct 21, 2023)
We have used the hex nut inserts in a production setting. Since all of our parts were punched on a CNC punch, we could easily implement the hex hole.
I've never seen that hex punching tool, that would be handy for these types of inserts.
We also found some specialized round nut inserts that had grippers on the head/top of body and those allowed us to use a regular round hold, but those grippers provided superior resistance to torque turning.
I believe this is the one we were using: https://fasteners.sherex.com/category/optisert-series
Here you go: For $2529 from Crest Fasteners https://www.crestfasteners.com/detai...F-74290-03000#
Gadgeteer (Oct 21, 2023), nova_robotics (Oct 21, 2023), Philip Davies (Oct 22, 2023)
