Results 1 to 6 of 6
Thread: Inside a wind turbine during high winds - GIF
  2. The Following 6 Users Say Thank You to ToolTalkBot For This Useful Post:
    nova_robotics (Oct 14, 2024), philippacificnw (Oct 14, 2024), Ralphxyz (Oct 12, 2024), rlm98253 (Oct 13, 2024), tuchie (Oct 17, 2024), Tule (Oct 13, 2024)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    No thanks!!!
    I cha hear one of my old iron worker buddies now , Just jam a sleever bar in there then when the other side comes around stab it with your spud get this thing bolted up there's cold beer's waiting
    May 2015
    Tasmania, Australia
    Bony's Tools
    Why is the tower bending so much yet the tower next to it, a crane?, so steady?
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Why on Earth would they be trying to assemble that thing in such horrible conditions? They certainly wouldn't operate it in that kind of weather.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    Quote Originally Posted by schuylergrace View Post
    The wind may have been dead calm at the beginning of the lift. This could just be a short period of gusts. The nacelle is already above the mounting point, the reason why the turbine tower is swaying is because of its surface area. no matter which direction the wind blows the cylinder is still going to be a huge sail in the wind. the lattice tower of the crane not as much by comparison. the Nacelle would rotate on the hook to present the least amount of wind exposure. At this point about all they can do is wait it out gusts of wind unless accompanied by storms or atmospheric pressure fronts are usually short lived. Once they do manage to stab the bolt holes with their bars or spuds the weight of the nacelle will have a dampening effect on the tower to an extent.
    When we were installing some equipment on the Burj Khalifa we could feel that thing sway several meters on the 122nd floor while the big ugly skyscraper was still being built.
    schuylergrace (Oct 12, 2024)
