Results 1 to 10 of 12
Thread: Induction pipe end sealing - GIF
    Induction pipe end sealing.
    Induction bender for large pipe - GIF
    Induction heating pipe fittings - GIF
    Induction heating sprocket teeth - GIF
    Induction forge - GIF
  2. The Following 12 Users Say Thank You to Altair For This Useful Post:
    baja (Jan 24, 2021), dubbby (Jan 23, 2021), jimfols (Jan 21, 2021), mwmkravchenko (Jan 23, 2021), nova_robotics (Jan 21, 2021), Priemsy (Jan 23, 2021), Ralphxyz (Jan 21, 2021), rdarrylb (Jan 22, 2021), rgsparber (Aug 20, 2024), Scotty1 (Jan 21, 2021), toeless joe (Jan 21, 2021), Tule (Jan 24, 2021)
    Sep 2018
    nova_robotics's Tools
    That is just a thing of beauty.
  4. The Following 2 Users Say Thank You to nova_robotics For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    I wonder if it is water tight? I need to learn about induction heating unbelievable how fast that heated.
    Ralph
    Sep 2018
    Ralph
    You can get very cheap induction heaters from any of the usual scumbags. I have a tiny little 12v heater (unknown wattage) and a much bigger 1000 watt (variable voltage) unit. Looks like there are 2000 watt units for between $60 and $80. Just a quick tip, if you're trying to power them up don't put them on a bench power supply and slowly increase the voltage because you're afraid they'll explode. Apparently they require the "kick" from the power supply turning on to start oscillating.
    1000 watts won't heat anything nearly as fast as in the video, but you can still easily heat things up to be red hot.
    almost magical. I wonder if they would work to heat up a rusted bolt for easier removal
    Sep 2018
    Quote Originally Posted by ibdennyak View Post
    Yup. There are even special bolt remover induction heater wands. It's just like a stick with a bunch of different coils you can put at the end to get into different places. They're like $250 - $300. I've never used one, but I've been drooling over them on Aliexpress for a while.
  9. #7
    Jan 2016
    Moby Duck's Tools
    Is a pipe with a sealed end still a pipe?
  10. #8
    Feb 2019
    A mechanic friend of mine has one of those sold by one of the bigger name tool suppliers that I have borrowed a few times. The thing is super handy and very effective. Heats a nut up to red heat within 20 or 30 seconds. No open flame of a torch and restricts the heat pretty much to just where you need it. It's a really useful tool for those occasions when you need such a thing.
  11. The Following User Says Thank You to clavius For This Useful Post:
    nova_robotics (Jan 22, 2021)
  12. #9
    Sep 2018
    Quote Originally Posted by clavius View Post
    Well dammit. Now I have to buy one.
  13. The Following User Says Thank You to nova_robotics For This Useful Post:
    clavius (Jan 28, 2021)
  14. #10
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    I'm right there with you. I did a quick google search and this one popped up on Amazon. There is a great video along with pictures. The video gives a great description of how to use the tool. As well as how not to use it. I'm adding it to my list of wants!
    https://www.amazon.com/Bolt-Buster-B.../dp/B00ATSL7VE
  15. The Following 3 Users Say Thank You to Rikk For This Useful Post:
    clavius (Jan 28, 2021), Jon (Jan 25, 2021), Ralphxyz (Jan 25, 2021)
