Improvised chain oil filter wrench. Of course, having this much access to an oil filter is a dream.
JM3 oil filter wrench Kickstarter
Andyt (Mar 31, 2020), baja (Mar 31, 2020), hansgoudzwaard (Mar 31, 2020), HobieDave (Mar 31, 2020), jimfols (Mar 30, 2020), mwmkravchenko (Mar 30, 2020), Rikk (Mar 31, 2020), sak778 (Dec 4, 2021), Scotty1 (Mar 30, 2020), Seedtick (Mar 30, 2020), Tooler2 (Mar 31, 2020), verticalmurph (Mar 31, 2020)
Yup, great idea, will use it where possible.
Many years ago, I had a filter remover made by Snap-on it comprised a backing plate with a hex welded to one side and a spiral spring (clockwise) projecting from the other. when you wound it "on" the spring opened up to accommodate nearly any sized filter, as soon as you applied anti-clockwise rotation it locked on allowing you to unscrew the filter.
There are two troubles with it (1) Snap-on don't make them anymore, and (2) it was so good that someone stole it.
