Results 1 to 9 of 9
Thread: The importance of maintaining the tape measure hook - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    Andyt (Jan 9, 2022), clydeman (Jan 12, 2022), durrelltn (Jan 8, 2022), johncg (Jan 9, 2022), nova_robotics (Jan 8, 2022)
    hemmjo's Tools
    I like Tommy, BUT, you need to be careful when you "Let it slam on your finger". If you allow you finger to come in contact with the EDGE of the blade as it slides in, it can slice you open!!!
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Ain't no big secret about the reason for the movement. Will letting it slam home eventually make it significantly inaccurate. Maybe if you use it all the time. I don't worry about mine.
    hemmjo's Tools
    Depends on the quality of the tape and how far you let it retract without restraint. I have seen them break the spring when allowed to slam shut. Has never happened to be as I do not let mine slam shut. Mine always wear out when the plastic coating wears off the backside of the blade.
    Mar 2018
    So if my house is all built with a 1/32" tolerance instead of a 1/16" tolerance because I let my tape "slam" shut... Who cares?
    hemmjo's Tools
    Quote Originally Posted by Hoosiersmoker View Post
    You can certainly work to whatever tolerance you choose. Different applications require different tolerances.
    As mentioned earlier, letting the tape slam shut can also break the tape. Some tape measures have a rubber bumper to absorb the shock if allowed to slam shut.
  8. #7
    Mar 2018
    But if I'm working to a close tolerance, my tool of choice is not going to be an el cheapo Stanley retractable tape measure and my reference was to building a house.
  9. #8
    Dec 2020
    It is getting difficult to buy a decent tape measure that will stay straight any distance without buckling and snapping.
    They are all made in China and other foreign sweatshops etc. Even Lufkin etc.
  10. #9
    re *1st post and related comments. There is a short sales video online, demonstrating the inside/ outside feature WE understand.
    It portrays it as a detriment, showing the controlled movement as if it were a defect.........in a weak effort promoting their tool.
