Results 1 to 4 of 4
Thread: I made a bearing bump tool for my Mini Lathe
    Supporting Member Guy Marsden's Avatar
    Mar 2022
    Maine USA
    Guy Marsden's Tools
    A bearing bump tool makes it much simpler to center stock with long stick-out in the 3-jaw chuck. No more tap-tap-tapitty-tap! I saw James use one on his Clough42 YouTube channel and had to make one!
    "Do or do not, there is no try" - Yoda
  2. The Following 5 Users Say Thank You to Guy Marsden For This Useful Post:
    Claudio HG (Mar 26, 2023), cognitdiss (Mar 26, 2023), EnginePaul (Mar 20, 2023), Jon (Mar 17, 2023), Scotty1 (Mar 20, 2023)
    Thanks Guy Marsden! We've added your Bearing Bump Tool to our Lathe Accessories category,
    as well as to your builder page: Guy Marsden's Homemade Tools. Your receipt:
    Marion, Iowa
    metric_taper's Tools
    I'm going to remake the two I have, one for my big lathe that uses 400 series QCTP, and the other for my 100 series QCTP. The problem I ran into, I had to swap the roller around to go from doing a thin plate in the chuck to a short cylinder. The steel square stock I have is too short to just add the second bearing. That is it's too short for the tool holder, as I used scrap brazed tool shanks to make these.
    The other thing, you don't need to notch out and have the bearing installed with its axis perpendicular to the square stock, rather drill right into the end of the stock and reduce the extra machining. I'm not picking apart what Clough42 did, but I'm guessing he copied someone else's design.
    These really are handy.
    Looks like keystock was used for the project, that's hard steel.
    <edit>
    I'm thinking round bar could be used and a boring tool holder. This makes it a pure lathe operation. But square is a 4 jaw chuck setup, and it's good to swap chucks out and dial stuff in.
  5. The Following User Says Thank You to metric_taper For This Useful Post:
    Guy Marsden (Mar 20, 2023)
    Claudio HG's Avatar
    Sep 2019
    Venetian Alps, EU
    Claudio HG's Tools
    This is definitely a tool that I'll make too. Thanks for posting.
