Results 1 to 5 of 5
Thread: I do not know what this part of the tool is for ?
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    I bought this tool from the restore because I do not know what the end is used for
    It’s a scraper there was 2 of them this ones end opens up and click locks in place
    With some kind of hex on the inside
    I can not see using this tool as a driver ?
    If you know what its for let me know
    Ray
    having a hard time uploading photos
  2. The Following User Says Thank You to shopandmath For This Useful Post:
    baja (Jul 7, 2019)
    hemmjo's Tools
    The tool is designed for scraping paint, like on the side of a house, etc. It is supposed to be a multi-tool.The hex is for a screw driver bit. It comes with a double ended straight/phillips. It can also be used as a narrow scraper.
    Just a gimmick in my opinion. I was a sucker, and got one. The bit was always falling out. If you use the butt to set a protruding nail, you mess up the flip out thing.
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    you are right
    the tool just falls out what junk
    and even with the smallest bit it will not close ?
    trying to attach photoI do not know what this part of the tool is for ?-tool.jpg
    hemmjo's Tools
    The bit it comes with is very short, flat on one end, phillips on the other. I lost mine in the grass the first day, within the first 1/2 hour.
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    I have one in my toolbox at work, works fine if you need to remove a screw without climbing down and back up the ladder for a screwdriver when you're scraping paint. Like all multi-tools, it's a compromise. Better than nothing, not as good as a single-purpose tool. I didn't buy it, just found it in a bunch of tools left by a previous tech. It does come in handy.
