Results 1 to 6 of 6
Thread: hydraulic briquette press machine (II)
    Supporting Member darkoford's Avatar
    Jul 2017
    Croatia
    darkoford's Tools
    -7.5kW/380V
    -200 bar
    -hydraulic cylinder fi 110mm/50mm x 400mm
    -hydraulic oil min.30l, max.80l
    -briquette fi 75mm
    -safety control voltage - 24V DC
  2. The Following 11 Users Say Thank You to darkoford For This Useful Post:
    Frank S (Dec 26, 2018), jackhoying (Dec 25, 2018), Jon (Sep 4, 2018), LMMasterMariner (Sep 4, 2018), olderdan (Sep 6, 2018), PJs (Sep 10, 2018), rlm98253 (Sep 4, 2018), rossbotics (Sep 5, 2018), Seedtick (Sep 4, 2018), sossol (Sep 7, 2018), that_other_guy (Dec 26, 2018)
    Thanks darkoford! We've added your Briquette Press to our Miscellaneous category,
    as well as to your builder page: darkoford's Homemade Tools. Your receipt:
    Dec 2016
    Nice machine. If you do a lot of cooking, that little press will pay for itself quickly at the current price of those wood pucks. Do use anything for a binder, or is it just wood only?
    Jul 2017
    Croatia
    darkoford's Tools
    Price of briquette in Croatia is $2-10kg . I can make 200-300kg / h depending on the type of wood.
    Only dry wood without binder.
    Feb 2018
    What creates the resistance to compress the sawdust rather than just push it out loose?
    Jul 2017
    Croatia
    darkoford's Tools
    The tube has a cone (1-2 °) inside and it provides great resistance to the passage of sawdust.
