Results 1 to 4 of 4
Thread: How To Use Mach3 Wizards - OD Taper on DIY CNC Lathe
    Supporting Member GBWM's Avatar
    Nov 2021
    GBWM's Tools
    Hello. I made a short video on how to generate some Gcode using Mach3 Wizards in Mach3. Quite useful for simple turning operations. I use it sometimes to generate codes for my LinuxCNC based DIY CNC Lathe. I hope this video will help somebody!
  2. The Following 2 Users Say Thank You to GBWM For This Useful Post:
    Jon (May 19, 2022), nova_robotics (May 16, 2022)
    Sep 2018
    nova_robotics's Tools
    Thanks. Do you prefer LinuxCNC or Mach3?
    Thanks GBWM! We've added your Turning G-Code to our CNC category,
    as well as to your builder page: GBWM's Homemade Tools. Your receipt:
    Nov 2021
    GBWM's Tools
    I've had Mach3 on my first CNC mill for wood. Worked quite well with a CNC USB board. But LinuxCNC allows for using incremental encoders for spindle which allows for threading operations - this is why I prefer LinuxCNC. Also LinuxCNC seems to work much better on parallel port but this may be affected by using Linux instead of Windows.
