How Korean steamed tree bark paper is made.
1955 paper digester - photo
How paper is cut - GIF
Toilet paper packing machine - GIF
Manufacturing Xuan rice paper - GIF
1692 De Schoolmeester paper mill GIF
You cannot get a clear idea of what is going on unless you have seen this process first hand.
beginning with the depositing of a thin layer of emulsified pulp on the brown sheet the water pulp solution drains through the membrane then the man is removing it and as he gently rolls the membrane off the stack of sheets the paper is deposited to the sheet of paper below it. He then carefully removes these sheets 1 at a time to be hung on the drying wall then stacked and trimmed the trimmings are returned to the emulsifying solution
baja (Oct 20, 2019)
