Results 1 to 1 of 1
Thread: How to set a flat end countersink or chamfer mill at the correct depth.
    Supporting Member Mook's Avatar
    Sep 2023
    Mook's Tools
    Setting the depth of chamfering tools & countersinks can be a pain especially if there is not a very sharp point to work from. This video shows how to measure & calculate the depth offset for a tool. Knowing this constant offset allows for accurate countersinks & chamfers to be machined. It is a surprisingly simple formula to use once the offset for the tool is used.
    The individual tool depth offset constant is referred to as k
    The tool radial offset & chamfer radius are referred to as r
    The chamfer width is referred to as w
    These are used in the description below.
    The depth for a given countersink radius r is. r-k. Yes it's that simple.
    The depth for a chamfer width w is (r+w)-k. Where r is the radial offset.
    The k value is individual for each tool, the tool diameter has no effect on the k value.
    There is a full desription how to easily find the k value for any tool.
  2. The Following 3 Users Say Thank You to Mook For This Useful Post:
    freddo4 (Nov 8, 2023), johncg (Nov 8, 2023), nova_robotics (Nov 7, 2023)
